Parting Out in AZ
Bull Run
AZ
2015 Mustang EB Prem PP
I’m 99.99% sure that the engine has a blown head gasket, likely due to running lean from clogged up injectors. The car still runs but idles rough and some coolant disappears overnight.
After much thought, I decided to just part-out as the car already has some body damage in the right rear (frame seems to be straight with good alignment, but probably will cost a few thousand to fix). I don’t want to spend the time and resources to fix the head gasket just to find out there are bigger issues as I’d rather save money for the upcoming S650.
Posting it here first to gauge the local interest before posting them in the classified section, since some of the parts (e.g. CF hood/trunk, sway bars, drive shaft, etc) aren’t cost effective to ship.
Also, is there a company than can haul away cars without wheels? I imagine dollies will be required to move the car out of the garage once it’s stripped of useful parts.
For GT, EB, or V6
Wheels
4x Advanti DST Hybris Lightweight wheels, 19X9.5
2x Advanti DST Hybris Lightweight wheels, 19X8.5 (option to stagger with the above wheels)
TPMS sensors for all
Brakes
Front GTPP Brembo 6 piston brake calipers
Front EradiSpeed+ 15" 2pc Rotors
Rear EradiSpeed+ 13" 2pc Rotors
Steeda Stainless Braided Brake Lines
JLT Brake Cooling Kit
G-LOC R10 Front Pads
G-LOC R8 Rear Pads
G-LOC GS-1 Front and Reader Pads
Titanium Shims
Chassis and Suspension
BMR Cradle Bushing Lockout Kit
Steeda Strut Tower Brace
Steeda Extreme G-Trac K-Member Brace
Steeda Pro Action fixed shocks and struts
Steeda Billet Rear Shock Mounts
GT350R Front Sway Bar
GT350R Rear Sway Bar
Steeda Ultralite Sport Springs Linear
Steeda Front Camber Plates
Steeda Aluminum Differential Mount Bushing System
Steeda Alignment Kit for BMR CB005
Steeda Rear Adjustable Camber Arms
Steeda Bump Steer Correction Kit
Steeda Front Control Arm Lateral Links w/ Extended Ball Joint
Steeda Toe Links with Ford Performance Knuckle to Toe Link Bearing Assembly
Steeda Front Control Arm Tension Links with Spherical Bearings
Steeda Front Control Arms Lateral Links w/ Extended Ball Joint
Steeda Vertical Links with Polyurethane Bushings
BMR IRS Subframe Support Brace System
Body
Trufiber Carbon Fiber CS8 Trunk Lid
Tig Vision Front Bumper Bar
Corbeau A4 Wide Racing Seats - Black Microsuede
Corbeau Double Locking Seat Brackets
Trufiber Carbon Fiber A81 Hood (Fits 2015-2017)
Husky front, rear, and trunk liners
EcoBoost Specific
Airflow and Fuel
Velossa Tech Big Mouth Ram Air Kit with GT Upper Grille
Airaid Intake Kit (453-326) with dry filter
GoFastBits DV+ BPV upgrade
Vargas Stage 2+ Turbo
AEM charge pipes
ETS FMIC
XDI Evo HPFP
PCV
UPR Dual Valve Catch Can
Radium PCV Baffle and Valve
Ignition
Granatelli Xtreme Pro Series Ignition Coils
Exhaust
MBRP Catless Downpipes
Corsa Catted Downpipe with Vibrant Resonator (3" inlet, 3" outlet)
Magnaflow XL Muffler (3" inlet, dual 2.5" outlets)
Drivetrain
DSS CF Driveshaft
Tune
Cobb AccessPort V3
Stock parts and trims from 2015 Mustang EB Premium PP
glockholiday
Wild Wild West
Jeff
2019 Mustang GT Premium
What color are the wheels and how much for all 6? I'm just west of Phoenix
Redfuzzbutt
Northern AZ
'17 Mustang GT
For GT, EB, or V6
Wheels
Brakes
G-LOC R8 Rear Pads
Titanium Shims
Steeda Toe Links
Steeda Rear Lower Control Arm Spherical Bearings
Body
EcoBoost Specific
Airflow and Fuel
AEM charge pipes
ETS FMIC
XDI Evo HPFP
PCV
Ignition
Exhaust
MBRP Catless and Catted 3" Downpipes
Drivetrain
DSS CF Driveshaft
Tune
Cobb AccessPort V3
Aw man, seeing a number of things that I would love to have but with Christmas coming up and a big vacation planned in January, I don't have the extra funds to make this a reality.
Sorry to hear about the car but best of luck with the parting out sale!
Bull Run
Bull Run
AZ
They are black. I'm looking for about half price of new ones for quick sale, so does $800 sounds good? They come with TPMS sensors and tires, but tires are well worn/bald so I'm not factoring in their cost.
That goes for the rest of the parts, which I'll initially price for 1/2 of the new price unless they are in bad shape.
Bull Run
Bull Run
AZ
Thanks brother!
compprep
Central, New York
Jim
19 GT PP1, 86 SVO, 24 S5, 74 MGB GT
PM sent on rotors.
Bull Run
Bull Run
AZ
Going on a vacation starting later this week, but will answer PMs meanwhile. I started crossing out items that are sold or reserved. Will continue pulling parts and posting them in the classified section when I return.
AZ18yote
Arizona
Bryan
Best of luck on the part out!
Just curious if you knew the weight difference between your CF trunk lid and oem?
Bull Run
Bull Run
AZ
Thanks! I wasn't able to weight the trunk lids correctly (as mentioned in the build thread below) but the weight thread lists stock at around 30 lbs and Trufiber site said their lid weighed 15 lbs. It definitely feels lighter and I didn't have any issues installing it by myself.
https://www.mustang6g.com/forums/th...-trades-2015-eb-premium-pp.99290/post-2241961
Cheo
Arizona
Mustangs
Got a price in mind for the Brembo's?
Bull Run
Bull Run
AZ
Most of the trim agonistic parts are sold so I'm listing the reminding ones here with prices:
I'll need your stock part in exchange for the four suspension items listed below. They are discounted accordingly to reflect this. I can ship them but I'll need your stock part shipped to me first to swap.
Steeda Rear Adjustable Camber Arms: $170 plus your stock part
For local pickup only:
Steeda Strut Tower Brace: $50 (marking this extra cheap as it has blemishes that do not impact the functionality)
Tig Vision Front Bumper Bar: $50
Husky front, rear, and trunk liners : $100
JLT Brake Cooling Kit: $50
Also have full interior from 2015 EB PP Premium minus the boost/oil pressure gauge and the center trim for it.
SunBoost
Maricopa, Arizona
Devin
2015 EcoBoost Premium Convertible
PM'd re: Steeda Strut Tower Brace
Bull Run
Bull Run
AZ
One of the guys that came by to look wants to buy the rolling chassis so I at least know that she'll live on as a project car. I'll
I found stock front control arms and rear toe links cheap on eBay so I will swap them out over the next weekend and put the following ship-able items in the classified section afterwards.
Thanks for your interest and I'll continue lurking here and in the 7th Gen forum.
