bconnaway
My Mustang has been having this code pop up for a few months now and I'm completely stumped. My SCT shows it is for Crankshaft Position - Camshaft Position Correlation Bank 2 Sensor A. I was drag racing my car at the time the code first came up. Pass felt good, did rev it to around 7500 RPM. Wasn't until I got back to the pit I noticed the check engine light.
So, I got the car towed home so I could start troubleshooting. From what I understand, bank 2 sensor A is that top (intake) cam on the driver side. So I pulled the driver valve cover to inspect. Everything looked good on the timing system (chains were snug and no exploded pieces anywhere). At that point I thought it may have been a bad sensor. I ordered and installed a new cam position sensor (part #9L8Z-6B288-B). Also did a crank relearn after that install. Code didn't come back on at first, but after a few days, it popped up when I was starting my car one day. I was able to clear that code and it didn't come back on for several days. After I had the code come up again, I ordered and installed a new VCT solenoid for that cam (part #BR3Z-6M280-E) and did another crank relearn. Again, didn't get a code for a bit, but after a few days I got the code on a startup. I was able to clear the code and it didn't come back on after driving about 100 miles. But just a matter of time till I see it again I assume I'll see it again.
So any ideas on what may be happening or what I should try? Car is does have a Paxton supercharger with 3.6" pulley and PBD tune on 93 oct.
