Oil Catch Can
mad murph
United Kingdom
2021 Fighter Jet Grey Mach 1
This may be a stupid question, so apologies if it is, but being new to mustangs does the S550 come with an oem catch can and, if so, should I be checking it regularly?
See lots of posts about people putting aftermarket ones on and wonder what the benefit is?
Thanks
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
No it doesn't come with one.
Does it neeed one? For a N/A street car, debatable, for a tuned or FI car it's a lil more needed.
Put it this way, they're good for a bit of peace of mind.
3-5k miles is the best timings to check/empty it.
GR11M
Herts, England
Graham
Ford Mustang GT
Grhumpy
New Caledonia
Jerome
Mustang 2015 GT - Impact Blue -
Hi, I'm just questioning myself, why ther's no oil in the driver side's catch can ?
So It doesn't need to fit both of them ? or ...
avocet
Kent, England
Ted
Mustang GT
I haven't fitted one to my 18 yet.
For some reason i thought they weren't needed on the new engine,compared to the 2015 /17 coyote engine.
I suppose it wouldn't hurt to fit one.
Entai
Bedfordshire
2019 GT kona Blue, A10, Magneride, CP 2. Daily Driver
Technically (and ok maybe slightly pedantic too ) but neither of those items inked to are oil catch cans.
They are as their names say air/oil separators.
Air/Oil Separators effectively remove the oil from the air coming out of the engine’s ventilation/breather system via a two stage process using chambers in the system. The first chamber is designed to use centrifugal force to remove the oil from the air, the clean air is then pushed into a second chamber and extracted from the AOS to the engine while the oil is recirculated back to the crankcase where it belongs.
A Catch can is a tank that is put inline of the system to capture the blow by and hold onto it. Once this gets full, you are required to empty the can.
Air Oil Seperators are more expensive than your average catch can.
A Catch Can needs to be monitored to ensure that it does not get too full and stops doing it's job, where as a pure AOS seperates the two and sends them to their rightful places, so doers not get full or need monitoring.
A lot of catch cans on the market don't do a whole lot for the high boost cars due to the air being forced through so fast, however some with offset ports or baffling fix that problem by giving the air containing oil something to run into first creating separation.
Catch cans not only require you to monitor the tank, but you also need to closely monitor the oil level of the car as well, being that it does not return the oil to the crank case.
GR11M
Herts, England
Graham
Ford Mustang GT
I see oil in the drivers side (rhd) but not in the passengers side.
slowhand99
Surrey, England
Ben
Mustang GT Vert Race Red ord 26/03/15 del 24/03/16
So, equally pedantically, although Ford calls them separators they are in fact catch cans since although they separate the air and oil (via a mesh), they do have to be emptied.
