Gee
Looking to see if anyone has successfully added a sensor to the ngauge using the analog input harness from Lund for their boost box omega.
Scenario:
- Boost box connection to ngauge takes up all 6 pins on back. By doing this Lund effectively moved wiring of the second analog input to their device.
- Lund sells an analog input harness to wire up a second sensor (vac/boost reference is on analog input 1 - and works phenomenally btw)
- The harness has 3 wires (Red - 5V sensor power, Black - ground, Yellow - 0-5V input)
- From what I've read you can wire up a sensor, however I'm conflicted about the need for a pull-up resistor.
- After reading ngauge and zeitronic manuals (designed to work together), both mention that if you wire up a 2-wire sensor to user input 1 of the zeitronic Zt-2 or to either of the ngauge analog inputs, you need to wire in a 1Kohm resistor. It's documented in both mfg manuals.
Just trying to gather some user input from those that have done it. My intention is to add a 1/8" NPT IAT sensor to the p/s of the whipple lower. I ordered an AEM 30-2014 sensor, have transfer function and this is the last part I'm looking to confirm from real life users.
Scenario:
