KadenW23
- May 9, 2016
- Dallas, TX
- Kaden
- 2015 Mustang Oxford White Ecoboost
Yeah, I actually have the stage 2 kit siting at home right now waiting to be installed. and yes, you can activate and deactivate it, but you have to make sure you have some sort of hand held tuner that will allow you to switch back to a regular tune that will not require a meth inject. I believe that it was huge advantage to the stage 3 kit though, if you were to ever run low on fluids, it will automatically down tune the car, or something along those lines. basically preventing you to go into boost or strain your engine. I'm not 100% sure, so do not quote me on that. but I could see spending $400 more on a kit when I could save that and it may just take a little more time and force me to be a little more careful.[MENTION=23881]KadenW23[/MENTION] I was looking at the Snow Performance Boost Cooler Stage 2 with the Snow Boost Juice. Now do you know if i need a throttle body spacer for this kit? are u able to active or deactivate this kit when needed? Let's say if i ran out of juice and don't got any in hand?
Also I would say the easiest way is to just order a spacer to install with the kit, otherwise you will have to drill/cut into a factory hose somewhere to install the injectors. the spacers are just a thread-and-go design making it extremely easy to install the injectors before the throttle body. If you ever need any help with the install just shoot me a PM, I would be more than happy to help in any way.
