New Steeda S550 Subframe Alignment and Bushing Support System!
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Steeda has come out with a kit that all S550 Mustang customers have been waiting for… The Steeda S550 Subframe Alignment and Bushing Support System!
Product Benefits
· Our IRS Subframe Bushing Support system fills in all factory voids in order to eliminate movement of the IRS subframe
· Utilizes all 4 factory mounting locations, which completely restricts shifting or rotation (Competitors only support 2 locations)
· Practically no added weight to the vehicle
· Uses precision machined Delrin sleeves which adds no NVH and limits vibration to the vehicle
· CNC Machined parts for a precision fit unlike welded and stamped parts with slotted holes
· Aligns AND holds the subframe in place, in all 4 mounting locations
· Easy installation, can be done in under 2 hours
· More cost effective than others on the market to control wheel hop
We combined our ever so popular 555-4438 and 555-4437 kits into a money savings combo kit where you the customer benefits! The S550's subframe mounting holes are very large compared to the subframe mounting bolts. Since there is a large difference in bolt and hole size, the subframe can be mis-aligned from the factory up to 1/2" left to right. The Steeda S550 Mustang IRS Subframe Alignment Kit is made from CNC-machined Delrin to avoid putting two dissimilar metals next to each other, preventing corrosion. Delrin is also less weight than aluminum or steel inserts and therefore keeping performance in mind. The Delrin sleeves slide into the subframe mounting holes, and fill the extra space left between the subframe mount and bolt from the factory therefore eliminating any movement. Our Steeda S550 Mustang IRS Subframe Alignment Kit guarantees that the subframe will be bolted to the same location every time it is lowered. Eliminating the need for unnecessary subframe alignments.
All for only 149.95
SteedaTech
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Hi Everyone, just got the sales report on this kit tonight total of 47 this week.
Thank you! And all the S550 enthusiasts, for your support to Steeda and all the vendors on this forum!!
Team Steeda!
JohnK
Seattle (Bothell), WA
2015 GT PP Ruby Red
How much has this reduced rear wheel hop on the S550? Any increase in NVH?
SteedaTech
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
No NVH or ride height changes. Depending on tires and set up it is subjective. It's a great start to your foundation on limiting your axle hop.
revtime
Midwest
2016 Mustang V6
Completely new to these IRS.
Will the car need to be aligned after installation?
Rebellion
Houston
2016 Competition Orange GT
Yes. The alignment might not change (most likely it will), depending on your initial tolerances and assembly, but it's always nice to be sure that the alignment is spot on.
