Hello All:
We have some great news here at Steeda ... the Steeda S550 Mustang IRS Subframe Bushing Support System now has a design patent -*PATENT NO: US D784,881 S*
A great design warrants an investment to protect it!
Made from CNC machined, 6061 aluminum, our bushing support system gives the rear end a much more solid feel with no increase in NVH at all. The Steeda IRS subframe bushings eliminate rear subframe movement notorious in the 2015 Mustang GT, EcoBoost, and V6.
A stiffened subframe allows the car to increase traction to the rear wheels and helps eliminate wheel hop.
Our Steeda IRS Subframe Bushing Support System (Part #: 555-4437) is very easy to install with basic hand tools and does not require any permanent modifications to the car.
Steeda Kit Pros:
- Helps reduce wheel hop by eliminating subframe movement, therefore giving you much better rear suspension compliance
- No permanent modifications are necessary
- Easy, 30 minute installation, can be done on jack stands in the garage
- Our kit doesn’t increase NVH at all
- Can be removed or installed in less than 30 minutes
- Completely eliminates over ½” of travel in the factory IRS subframe
- Doesn’t require a rear end alignment
- Lifetime warranty
- Track-tested at the drag strip and the road course - we are not just straight line people
Steeda Kit Pros:
- Lifetime warranty
