- Aug 9, 2014
- Fort Bragg, NC
- Jason
- 15 PP
Some new and exciting parts from BMR, greatly decrease wheelhop and Stabilize that rear end! Check them out at www.hypermotive.com! Any questions at all just let us know!
http://www.hypermotive.com/bmr-bushing-kit-rear-cradle-poly-15-mustang/
Significantly reduce rear cradle movement in your S550 Mustang with a Polyurethane Rear Cradle Bushing Kit from BMR Suspension. These bushings are made from low-deflection, 95-durometer polyurethane, which is known for its high stiffness, low friction and excellent stability. This product greatly reduces bushing deflection that occurs during acceleration, cornering, and braking with only moderate increases in NVH. Each bushing is designed to exact tolerances, which are designed by BMR. This allows for a perfect fit and increased performance for any driving style. The BMR Poly Rear Cradle Bushing Kit (BK047) greatly increases the rigidity and stability of the chassis to provide maximum control and consistency necessary for any form of competition or high performance street driving.
Designed for street performance, drag race, and handling applications, BMR Suspension BK047 Poly Cradle Bushings are the perfect wheelhop solution for any S550 Mustang where NVH is not a concern. BMR’s Rear Cradle Bushings reduce cradle movement over the stock rubber bushings. The OE bushings are designed with air pockets and are made from soft rubber. These “voids”, coupled with soft material produce excessive differential movement during normal and aggressive driving. BMR’s poly cradle bushings replace the entire OE rubber bushing, minimizing differential movement by replacing the soft rubber OE bushings with solid two-piece poly bushings. This reduces cradle movement, reducing wheelhop and increases handling stability, while giving you a much-improved overall feel in any performance driving situation.
BMR Suspension’s BK047 Differential Busing Kit is available in red with zinc-coated hardware. Installation time is about 3-4 hours and may vary depending on stock bushing removal technique. Proudly made in the U.S.A.!
http://www.hypermotive.com/bmr-bushing-kit-rear-cradle-delrin-15-mustang-gt/
BMR Bushing Kit, Rear Cradle, Delrin 15+ Mustang GT
Eliminate rear cradle movement in your S550 Mustang with a Delrin Rear Cradle Bushing Kit from BMR Suspension. These bushings are CNC-machined from Delrin, which is known for its high stiffness, low friction and excellent dimensional stability. This product removes all movement between the rear cradle and chassis, eliminating the bushing deflection that occurs during acceleration, cornering, and braking. This material eliminates deflection with only moderate increases in NVH. Each bushing is machined to exact tolerances, which are designed by BMR. This allows for a perfect fit and increased performance for any driving style. The BMR Delrin Rear Cradle Bushing Kit (BK048) greatly increases the rigidity and stability of the chassis to provide maximum control and consistency necessary for any form of competition or high performance street driving.
Designed for max effort street performance, drag race, and handling applications, BMR Suspension BK048 Delrin Cradle Bushings are the perfect wheelhop solution for any S550 Mustang where NVH is not a concern. BMR’s Rear Cradle Bushings eliminate cradle movement over the stock rubber bushings. The OE bushings are designed with air pockets and are made from soft rubber. These “voids”, coupled with soft material produce excessive differential movement during normal and aggressive driving. BMR’s Delrin cradle bushings replace the entire OE rubber bushing, minimizing differential movement by replacing the soft rubber OE bushings with solid two-piece Delrin bushings. This eliminates all cradle movement, reducing wheelhop and increases handling stability, while giving you a much-improved overall feel in any performance driving situation.
BMR Suspension’s BK048 Differential Busing Kit is available in black with zinc-coated hardware. Installation time is about 3-4 hours and may vary depending on stock bushing removal technique. Proudly made in the U.S.A.!
http://www.hypermotive.com/bmr-bushing-kit-rear-cradle-polyurethane-15-mustang/
BMR Bushing Kit, Rear Cradle, Polyurethane 15+ Mustang
Minimize wheelhop and enhance the rear stability of your 2015 and newer S550 Mustang by decreasing differential movement with polyurethane differential bushings from BMR Suspension. Polyurethane is a synthetic polymer with many properties that make it far superior to OEM rubber for bushings. Polyurethane deflects far less that soft rubber, and it doesn’t breakdown from exposure to petroleum products, road salt, ozone, and other elements of the harsh undercar environment suspension bushings live in. BMR Suspension’s polyurethane Differential Bushings (BK049) drastically decreases differential movement and pinion rise over the factory rubber bushings. BMR designed its polyurethane differential bushings from 95-durometer polyurethane. This material offers huge reductions in deflection without excessive increases in NVH. Each bushing is manufactured to strict tolerances, using exact molds, which are designed by BMR. This allows for a perfect fit and increased performance for any driving style.
Designed for street performance, drag race, and handling applications, BMR Suspension BK049 Differential Bushings are the perfect wheelhop solution for any S550 Mustang being used for performance driving. BMR’s Differential Bushings offer huge increases in performance over the stock rubber bushings. The OE bushings are designed with air pockets and are made from soft rubber. These “voids”, coupled with soft material produce excessive differential movement during normal and aggressive driving. BMR’s polyurethane differential bushings replace the entire OE rubber bushing, minimizing differential movement by replacing the soft rubber OE bushings with 95-durometer 4 two-piece polyurethane bushings. This eliminates almost all differential movement, reducing wheelhop and increases handling stability, while giving you a much-improved overall feel in any performance driving situation.
BMR Suspension’s BK049 Differential Busing Kit is available in red with zinc-coated hardware. Installation time is about 3-4 hours and may vary depending on stock bushing removal technique. Proudly made in the U.S.A.!
http://www.hypermotive.com/bmr-toe-rods-rear-double-adjustable-rod-ends-15-mustang/
Launching harder, reducing wheel hop, and adding cornering consistency to your S550 Mustang is easy with double-adjustable Toe Rods from BMR Suspension. Stock stamped steel toe rods with eccentric adjustment bolts deflect under load and change the alignment of the rear wheels. BMR’s double-adjustable toe rods for S550 Mustangs (TR005) are manufactured from heavy-duty 1 1/4-inch DOM steel tubing. TIG-welded chrome-moly tube adapters with a heavy-duty center adjuster make on-car adjustments simple and easy. The open end is formed from laser cut, CNC formed 3/16-inch steel plate. The CNC-machined center adjuster has right- and left-handed threads for easy on-car adjustments. This design gives you a strong toe rod that greatly improves adjustability. The other end features zinc-plated, X-series, heat-treated, chrome-moly, self-lubricating, Teflon-lined rod ends. It also features 304 stainless steel, custom designed rod end spacers.
BMR Suspension designed the TR005 to work well in street performance, drag race, and road race applications. The stock toe rods flex under cornering loads giving you inconsistent alignment and handling characteristics. Combine this with eccentric adjustment bolts that can't handle hard launch with sticky tires, or high-horsepower applications and you’re left with poor performance. The TR005 allows you to fine-tune the rear toe settings for any form of performance driving. BMR supplies lockout plates to eliminate the factory eccentric adjustment bolts. This allows you to make all of the adjustments on the toe rod. Lockouts are used to minimize toe change and deflection from the eccentric slipping and losing adjustment. Cars with more than stock horsepower levels or soft compound tires tent to push the limits of eccentric bolts in rear suspension systems. Other company’s adjustable toe rods reuse the eccentric bolts, which only fix half the problem. BMR’s TR005 Toe Rods are a complete solution. This is just another reason BMR’s double adjustable toe rods are the perfect upgrade for the enthusiast looking to improve performance at an affordable price. When performance is a must, rely on BMR Suspension!
BMR Suspension’s TR005 Double Adjustable Toe Rods are available in red and black hammertone powdercoat for long-lasting good looks. Installation time is about 2 hours. Proudly made in the U.S.A.
http://www.hypermotive.com/bmr-vertical-link-rear-lower-control-arms-spherical-15-mustang/
Launching harder, reducing wheel hop, and adding cornering consistency to your S550 Mustang is easy with billet aluminum Vertical Links from BMR Suspension. Stock stamped steel vertical links with soft rubber bushings deflect under load and absorb power instead of transferring it to the tires. BMR’s spherical bearing, billet aluminum Vertical Links (TCA045) are CNC-machined from 6061-T6 billet aluminum. This design gives you a strong control arm that greatly improves performance with zero deflection, without huge increases in weight.
BMR Suspension designed the TCA045 to excel in street performance, drag race, and road race applications. The stock vertical links flex under cornering loads giving you inconsistent handling characteristics. Combine this with soft bushings that have massive amounts of deflection, and you’re left with poor performance. The TCA045’s heavy-duty construction eliminates vertical link flex, giving you much improved repeatability on the street, starting line, or in the corners. BMR’s heavy-duty spherical bearings are designed to solidly link the spindle to the lower control arm, eliminate deflection and wheel alignment changes. Our spherical bearings will stand up to high loads of any performance environment, offering all of the bind-free suspension articulation needed for great handling. These are the perfect upgrade for the enthusiast looking to greatly improve performance without NVH levels being a concern. When performance is a must, rely on BMR Suspension!
BMR Suspension’s TCA045 billet aluminum spherical Vertical Links are black anodized for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.
- Fits 2015-newer S550 Mustangs
- CNC-machined 6061-T6 billet aluminum
- Spherical Bearings
- Custom designed billet aluminum spacers
- Eliminates vertical link flex
- Eliminates bushing deflection
- Eliminates wheel alignment changes due to vertical link flex
- Designed for street performance, drag race, and road race applications
- Durable anodized finish
- 1-hour installation time
- Proudly designed in the U.S.A.
- Proudly made in the U.S.A.
