Need knowledge!!
hmdballa219
Lake Station, In
2018 shadow black mustang GT
Oh ok so nothing crankshaft sensor circuit related.
hmdballa219
Lake Station, In
I don't know what he did to be honest . I bought him the little timing plug thing for Ford engines.
And no clue about a crankshaft tool. No he deff didn't use a tool. Just hooked up back up. Same way as I just did.
hmdballa219
Lake Station, In
Crankshaft position sensor tool.i should say.
perfweld
Northern CA
2015 Ecoboost Mustang
There you go, thats your problem. Do some google research on how to set it up, you have to find TDC with the crank stop, then use the alignment tool on the trigger wheel. Its not gonna be fun in the car BTW.
perfweld
Northern CA
It's messed up that they'd use a "Circuit failure" code for an alignment issue. On the Subarus they use a "performance issue" code for a misaligned component.
On this deal the tool when on the sensor sets the height and the rotation as well. So it could be way off and as the engine spins it might not even see any trigger. It just has to be done correctly, even if it did run.
hmdballa219
Lake Station, In
Ok thanks already guys. So does anybody have instructions on this. Can't find much about setting timing for this car
hmdballa219
Lake Station, In
Alot*****
hmdballa219
Lake Station, In
Right wtf!!!
CustomS550
South Carolina
2016 EB Mustang
Makes sense.
hmdballa219
Lake Station, In
Also does anyone know the exact name of the tool? Please need some help and advice here. Can't find anything.
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
PM your email address and I'll send you Ford's engine assembly instructions. It shows you how to use the tool to properly set the CPS. You'll have to have the CPS tool, TDC peg, M6 bolt, etc to do it properly. You can't guess at the CPS positioning and your mechanic should have known that.
And not trying to sound like a dick or anything, but if your mechanic didn't know about the CPS sensor, then that'd make me wonder about the rest of his work. If he has access to Alldata or similar and checked it, he'd know what he needed to do.
5.0yote
AKA Bananana & 3.7Cyclone
Mansfield, MA
www.youtube.com
Don
2016 Mustang Ecoboost Premium
That's the boost control solenoid, I believe.
Boost solenoid has 3 hoses, one harness and is mounted on the front face of the motor.
hmdballa219
Lake Station, In
Guys u won't believe this. The crankshaft position sensor was on backwards!!!! He out it on backwards so I did the same thing and was looking on a Mazda 2.3 forum and I noticed the picture of the piece was switched. So I switched it and fired right up!!!!! Just have a coolant line that needs to be fixed and I'm all good!!!!
5.0yote
Mansfield, MA
www.youtube.com
Don
aaand that ^
5.0yote
Mansfield, MA
www.youtube.com
Don
lol
