Need help installing vertical links!! Socal area
Chris97277
Souther California
2017 Mustang GT premium
Hey guys I need help installing vertical links ! Its been an absolute nightmare trying to install them so far and at this point i do not want to install the stocks again and take the car to a ship instead.
I can get the lower bolt aligned but no the top bolt. The socked for the top bolt is sitting too high still even when I don’t have the jack under the control arm. Then i try jacking up the control arm the socket just goes even higher and moves further up away from the knuckle.
Now, when I try doing it in reverse, i can get the top bolt aligned, but not the bottom bolt. Meaning, when I have the knuckle with the bolt in and lower the jack, the bottom bolt will be too high for it to align with the hole. And if i jack up the control arm, the entire vertical link will just move up away from the bottom hole since the top bolt is already in.
I NEED HELP ASAP!!
Jet
Pasadena
2016 mustang gt
Should be a simple install. Took me about an hour to do both sides
Ecoboosted
A state in the South East of the US
18' Mustang GT, 19' Road Glide
Yes I had no problems installing mine either.
