MY18+ Plastidip front [upper] grill :)
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Howdy.
So I'm going to swap out my OEM [upper] grill with an aftermarket that needs to be finished. I'm thinking Plastidip would be a good option - the stock upper GT grill is gloss, I'm thinking Plastidip would be a good match with the lower grill, that's just flat black plastic.
Anyone done a top grill? In particular a MY18+ (I'd like to see how the flat black works vs. the OEM gloss black). I found a few photos in some older threads, thought maybe a fresh thread would get some new contributions. :rockon:
FWIW, this grill is identical to OEM, just no pony, I'm going to be cutting out the corners and installing a pair of Velossa ducts :)
Geosh
Gilbert AZ
Josh
2019 Mustang GT
Howdy.
Plastidip is a good temporary option but if you want to keep it that way, use something more durable.
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
Howdy.
What grille are you using? Link? I just haven't seen one yet that's identical to OEM. Thanks!
MaskedRacerX
MaskedRacerX
Driver
Vilano Beach, FL
DT
FreePenguin
Ohio
Donald
17 mustang
will work, but pain in ass to remove I assume when it needs to be removed
MaskedRacerX
MaskedRacerX
Driver
Vilano Beach, FL
DT
FWIW, I picked up a can of Plastidip, going to do a test run on the corner pieces I cut out :)
Copperhead73
Knoxville, TN
Derrick
2019 Mustang GT Premium Convertible PP1, A10, Mag, B&O, A/E, S&S
Plastidip will get chipped up. Though if black over black, you may not notice.
Jmtoast
Michigan
2018 Roush GT
I had plasti dipped wheels at one time on car. What a mess. It's like having a giant scab. All of a sudden some it starts to peel and it drives you nuts until you've peeled that whoe thing of. But a grill is nothing like wheels in regards to chips rash, so might work out perfect.
MaskedRacerX
MaskedRacerX
Driver
Vilano Beach, FL
DT
Sounds like maybe I'd be better off with a painted/clearcoated finish.
Not in a rush, maybe I'll hit up a paint shop next week.
@Copperhead73 Got my ducts :D
Copperhead73
Knoxville, TN
Derrick
Grats! Pics when it's done, please!
I received a shipment notification for mine. I am itching to get after it.
I'm going to put splitter support rods on while I have the front end off. Hoping it won't be too tacky. Once all that is done, going to get the racing stripes I've been putting off for a year.
MaskedRacerX
MaskedRacerX
Driver
Vilano Beach, FL
DT
Do the stripes side to side vs. front to back, that'll be different ... :crazy:
Yeah, Velossa Tech is here in Florida so I got mine in basically a day after they shipped, they look awesome, great orange color match. I think going with a more muted flat black grill will really make them pop.
Copperhead73
Knoxville, TN
Derrick
The Hamburgler look!
MaskedRacerX
MaskedRacerX
Driver
Vilano Beach, FL
DT
OK, cut out one corner, went well, bottom side had a visible seam at the perfect cutting location, when I just pencilled in a line around the whole triangle, Dremel, fresh cutting wheel. I'll clean up the edge with a little sandpaper. I'll probably cut out the other one today, held up the orange duct, wow, looks awesome.
So I took the piece I cut out, and did a "test paint" with my Plastidip, just 3 coats, waited about 10 minutes between. Looks great! It really matches the lower front grill, and the ducts being glossy orange, really pop against the flat black.
More to come ...
