PamAndJim
I just finished it and installed it over the weekend. The process I used was:
-Scuff cover with scuff pad
-Clean thoroughly with Simple Green and water - let dry
-Wiped down with lint free cloth and Duplicolor Prep Spray
-Sprayed 2-3 coats of Duplicolor Adhesion Promoter
-Sprayed 4 coats of Duplicolor High Build Primer
-Wet sanded while piece with 600 grit, then 1500 grit
-Sprayed 4 coats of base coat colors
-Wet sanded again
-Sprayed 4 coats of clear
Overall, I am happy with the results. I learned a lot in the process. Originally I started with the Duplicolor Exact Match color that is supposed to be Oxford White. I was disappointed for a couple reasons, a.) It didn't even come close to matching and b.) There is very little paint in the can - it took 2 cans to get a good cover with the white. I ended up finishing it off with a can of Krylon Gloss White. I will probably end up redoing it once I can find a good solution to getting paint that matches the car (will either look into having a paint shop make up some spray cans, or I might buy a paint gun) I want to do the fuse box cover and the panel above the radiator. Those will wait until the paint situation is figured out. Enough words, how bout some pics?
Primed and Sanded:
Installed:
I thought I had more "in progress" pics, but this was all I could find.
-Wet sanded again
Primed and Sanded:
Installed:
