Mustang Morimoto XB LED Headlights
Status
Not open for further replies.
RPI Designs
Salem, Ohio
www.rpidesigns.com
2015 Mustang GT - Test Mule
https://www.rpidesigns.com/shop/item.aspx/mustang-morimoto-xb-led-headlights/
Wiring is easy and everything you need is included! No glue! Upgrade your Mustang today!
No Substitutes: If you don't have LED powered headlights on your Ford Mustang, then you're just behind the times! Thankfully the new Morimoto XB LED headlights look great and are well-built. They have a virtually infinite life span, an unbeatable warranty, and out-perform the alternatives. All this easily makes them the best Mustang LED headlights on the market today.
OEM Plus: While the Mustang LEDs from Morimoto cost a bit more relative to other options in the aftermarket; as the saying goes you pay for what you get. We've seen it all, and their fit and finish is far superior to everything else out there. Guaranteed.
Performance: We've always been blown away by the fact that the other brands don't even consider how well their headlights perform on the road at night. Most often, they're a downgrade compared to even the standard halogen setup, and that's a shame. The good news is that Morimoto's XB LED headlights produce a well defined beam pattern with a great amount of width, intensity, and a proper distribution of light.
DOT Approved: Make no mistake, these will produce a much different (better) result than slapping some LED replacement bulbs into your stock housings. Their projector optics meet & exceed all SAE, DOT, and FMVSS108 regulations when aimed properly...and that's easy to do with their integrated vertical/lateral adjusters.
Plug-N-Play: Wiring is easy too! The XB Mustang LED headlights are designed to work without any modifications. They will plug into the factory connectors for the stock headlights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No error codes, no flickering, hyper-flashing, or radio interference. They can easily be removed, and will not void your factory warranty.
LED DRL: Game Changer! The LED daytime running lights are powered by Osram 5000K LEDs and are insanely bright, easily visible during the day.
Well-Built: The UV-coated polycarbonate lens will resist the test of time, ensuring your Mustang headlights will look good as new for many years to come. The PPS plastic housing is light-weight and much stronger than comparable alternatives. The die-cast aluminum heat-sinks inside the housings provide more than an adequate amount of cooling for the OEM grade Osram LED chips that produce the light. These complete headlights may be new to the market, but Morimoto's XB LED fog lights have proven themselves perfect after 5+ years out now, which is confidence inspiring.
They Look: Amazing. At least in our opinion! The subtle elements incorporated in their design are more than enough to make them stand out, but they're clean enough to be considered original equipment to those who don't know any better. The piano black trim keep the color scheme neutral, and the kuria-optic projectors are as modern as it gets.
Technical Specs:
TRAFFIC PATTERN: LHD ONLY
INPUT: Proprietary Ford Multi-pin
WEATHER RATING: IP67 Waterproof
LENS MATERIAL: High Impact Polycarb (UV-Resistant)
LIGHT SOURCE: Osram Ostar Headlamp LED
LED OPTICS: Kuria Optics
INTENSITY: 2,600lm (raw; each)
COLOR: 5500K (Pure White)
Application 2015, 2016, 2017 Ford Mustang
zero_chance
Dismember
Arizona
JD
2017 GT Premium w/ Performance Pack
I was tempted by those but losing the tri bar DRL’s was a no go for me. The current led accents, while nice, are too reminiscent of a Dodge Charger for my taste. Still very sharp overall.
RPI Designs
RPI Designs
Salem, Ohio
www.rpidesigns.com
Well...thank you for considering us...Have a GREAT DAY!! We appreciate your feedback.
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
Don, what is the correct part # for the 2020 ? Also, need pricing.
Elvis67
California
Brandon
19gt ..19 ss 72 chevelle
These are new as well from raxiom
RPI Designs
RPI Designs
Salem, Ohio
www.rpidesigns.com
Status
