Motive Power Bleeder Simple Mod
Knockdown
Greg
2021 Mustang Mach 1
I use the Motive bleeder by just using air pressure on the master cylinder to avoid the cleaning of the unit and the waste of brake fluid. I recently did a full fluid flush to a high temp brake fluid and it’s a lot of hand pumping every time you need to add fluid.
I added a 1/4NPT FxFxM tee and a 1/4 NPT M Schrader valve in line with the Motive hose fitting so I can use my Mikita air compressor to pressurize the system. It’s much quicker, here’s a quick video.
