Maximum spacer size help
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Brice80
Brice
2015 Ruby Red GT Premium PP
of course, I normally have mine made at my local shop for my clients .
why dont you shoot me a pm I can have them made for you to spec :cool:
PM'd
there ya go... I would take advantage of this if I were you OP>;)
Schweet, :headbang: thanks man. hopefully I can finish up my research on spacers this weekend, figure out exactly what I want and then get someone like N4S to make it full package for me. install on these can't be much I imagine? never put them on, could do it myself I suppose?:shrug:
sstevens7
Tucson, AZ
2015 Mustang GT Premium w/PP
ok so are we saying that these spacers (see link) from AmericanMuscle are not safe? I am running the stock GT PP black wheels and the fronts are super tucked! I was going to put the 1.5 inch spacers up front and the 15mm in the rear. Doing the spacers until I can afford a set of wheels that have the right offset.
http://www.americanmuscle.com/15in-billet-aluminum-wheel-spacers-2015.html
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
those are considered adapters brotha, but those yes are safe, reason is a 5 mm spacer maxes out the amount of stud left for the wheel to mount onto and the amount of hub lip for the wheel to sit onto, at 5 mm the stud has enough to allow the lug nut to make proper amount of turns.
Anything more then that doesn't allow the proper amount of turns on the lug nut which is a safety issue thus recommendation is adapters so you have studs on the adapter to allow you to get the proper amount of turns.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
ok thanks, sorry for the confusion.
no worries bro, if you have questions you can even ask me through pm im here to help however.
gunsnbutta
its just a 2 door fusion
Dallas, Texas
TJ
2019 Mustang GT
Sorry to revive this thread but I just need a little more clarity. I ordered the 5mm spacers from AM and it does not say they are hubcentric. Is there enough hub left that I don't need them to be? I couldn't find anything 5mm or thinner that are hubcentric for our vehicles.
