krahooligan
The car creeps well. I have a similar commute as the OP described.
From what you said about your test drive it sounds like the auto is for you.Ya im guna go with the auto. For me and commuting mainly and drag strip it's better. Plus when I blow it will be able to handle it better. I also have a bike if I Wana shift gears and hit curves
I would never practice anything with a transmission I'm paying for. I drive a 13 speed Eaton transmission mack all day everyday. It took me a good six months of driving 12 hours a day to learn to float the gears perfectly. I'm sure there were quite a few transmissions that lost teeth along the way. Imo there's no reason Joe smo should be doing anything other than the standard push the clutch in shift gears and release clutch. Especially when one miscue could cost several thousands on repair costs.There is a noticable difference in how easy the shifter goes into gear with a well executed double clutch on the downshift (matches the intermediate shaft speed). Totally unecessary with a modern manual transmission with syncros especially if you are already rev matching on the downshift, but you can still feel it ease into gear easier.
Fun to practice, just another rewarding opportunity one has with a stick
And in 30 more years (if standard transmission vehicles are still around) the average person will not know how or what a double clutch is. Aside from truckers and the very select who race, this technique will likely die off.I agree there's no reason to do this in any car built in the last 30+ years, unless the transmission is worn out. All modern automobile manual transmissions are designed to automatically synchronize the speeds of the gears as you shift.
I had the exact same decision to make when purchasing my 2015 GT. I went with the manual and 3.55 gear ratio because I missed the responsiveness of a manual. My previous Mustang was a 2006 GT with auto and 3.31s and the constant 'searching' for gears and the hesitation when flooring it drove me nuts. However, as my spouse pointed out, I probably should have test driven a 2015 with the automatic before making a final decision. I've been in traffic many times wishing I had an automatic. Ideally, I would like to own one of each...Ya im guna go with the auto. For me and commuting mainly and drag strip it's better. Plus when I blow it will be able to handle it better. I also have a bike if I Wana shift gears and hit curves
Sport and track driving modes basically eliminates the hesitation and searching for gears. Best of both worlds. I got rid of my last car after 6 months because driving a manual is pointless and annoying in a passenger car. The auto gets better mpg, never misses a shift, and is built better. Oh and no clutch changes. This is just my opinion not trying to ruffle feathers.I had the exact same decision to make when purchasing my 2015 GT. I went with the manual and 3.55 gear ratio because I missed the responsiveness of a manual. My previous Mustang was a 2006 GT with auto and 3.31s and the constant 'searching' for gears and the hesitation when flooring it drove me nuts. However, as my spouse pointed out, I probably should have test driven a 2015 with the automatic before making a final decision. I've been in traffic many times wishing I had an automatic. Ideally, I would like to own one of each...
?hesitation and searching for gears
definitely untrue.driving a manual is pointless and annoying in a passenger car
Man I can row that manual like it was a third limb, thank you very much. Those are practices which extend the life of the manual transmission, as they rely muuuuch less on the syncros and reduce clutch wear when executed properly. Anyone with practice can do such things without even thinking, even in split second situations. There is no consequence to trying this except a 'typical' gearchange. And like I said, its more of a matter of driving enjoyment being more involved, and less about durability. It just so happens to be slightly beneficialI would never practice anything with a transmission I'm paying for. I drive a 13 speed Eaton transmission mack all day everyday. It took me a good six months of driving 12 hours a day to learn to float the gears perfectly. I'm sure there were quite a few transmissions that lost teeth along the way. Imo there's no reason Joe smo should be doing anything other than the standard push the clutch in shift gears and release clutch. Especially when one miscue could cost several thousands on repair costs.
