Cream Puff
Here is the wiring diagram for the premium system.
The front gear im using is a Hertz 2 way component set (6 inch and tweeter), with a separate 3 inch hertz woofer.
The crossover for the regular components is only for a 2 way setup, so I have also picked up a 300hz high pass filter for the 3 inch mid.
I noticed in the wiring diagram that the door 3 inch and tweeter share a circut, and i'll be tapping into the factory wiring wherever possible. So I have 2 thought processes here and looking for opinions on which way I should go.
Option 1:
Use factory tweeter wiring to the pillar, disconnect it from the door 3 inch.
By going this way I could tap off the woofer wiring in the door, add my small 300 hz crossover and my own wiring between the door woofer and my door mid.
Option 2: Use factory tweeter wiring to door, mount small 300 hz crossover in the kick panel above the factory amp.
Going this way I would have to run 2 new wires up to the tweeters, which is a LOT more work than just a little 12 inch wire between the 2 speakers in the doors.
Going this way would allow me to run active crossovers should I ever decide to do that, but is a lot more work up front.
Option 1:
