Livernois Intercooler & thermostat
ypena02
Massachusetts
2017 Mustang GT
beefcake
Bethel
2018 Ford Mustang
So why do cars run hotter in the summer?
just physics, if your in a climate that is substantially hotter, car is going to be hotter at a certain point
same thing when your at the dragstrip and its 90 and humid and your trying to cool down between rounds
takes forever
hit a fall track when it's 40 out, and you can round robin that thing
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
No official instructions just posts by ppl on here giving tips on the install. Basically you need to remove the throttle body which is actually pretty simple and then you can get to it pretty easy. You'll need a gallon of OEM coolant for the fluid u lose when u take the hoses off.
I didn't do it myself. Took it to evolution performance, when I told them what I wanted installed they said they had already done several of these so it was easy for them
Livernois Motorsports
Dearborn Heights, Michigan
www.livernoismotorsports.com
S550 HQ
2016 Mustang GT (TVS 2650) (6R80)
any install instructions available?
Take the intake tube off, remove the hose to the thermostat housing outlet. You will lose about a quart of antifreeze from that. Then remove the two 8mm bolts holding the housing outlet on. Once you pop out the stock thermostat you will lose another quart to half gallon of antifreeze. Put it back together in the reverse order. Let the engine run with the cap to the overflow tank off after I topped it off for about 15 minutes to get the air out. Just keep an eye on it and the temp gauge. After that take it for a quick drive then shut it down and let it cool completely. At that point you will see if you need to top it off.
turtleboy
Palm Springs, CA
15 EB
Is this a good mod for someone that lives in the extreme heat? Summer is 4+ month of 100 - 110 degree temps.
S550 HQ
It is! Heatsoak is a serious issue with the EB cars and trucks in general. Living in a more hot climate than "average" will aid in you reaching the heatsoak faster. So the more quickly and efficiently you can cool off the turbo system (intercooler) and engine (tstat) you will be able to have more fun more frequently. Even in cooler climates like here in Michigan there are distinct advantages to the same mods, and no negative effects in winter months either. Tune, CAI, tstat and FMIC are the perfect mods for a turbo car in any situation!
