Minnesota Listing for auction remove thread
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Listing for auction on Cars and Bids
I have an extensive build thread here: https://www.mustang6g.com/forums/th...n-f1a94-procharged-th400-drag-project.103207/
I have an instagram documenting the car here: https://www.instagram.com/turnswrench/
I have a youtube channel with several in depth videos showing the modifications of this car here: https://www.youtube.com/channel/UCZ-nb5fyYKDqrlDhVN_6F4Q
Car high level details:
2018 Mustang GT Royal Crimson 3,6xx miles
One owner, no accidents. Clean title in hand, no lien
1,075+whp: I have tunes for both 93 octane and e85 ranging from 700whp to ~1100whp
F1a94 stage 2 procharged with dual Tial BOVs, crank support, ATI balancer, turbo guard, 3.5" hard charge piping the whole way (no silicone elbows)
ATI SFI Supercase TH400 with transbrake, 10" outlaw ATI converter, roller bearing
FatHouseFab 8.50 certified chassis, 10 point cage, co2 Motion Raceworks parachute setup, Optic Armor windshield, car weighs ~3500-3520lbs
Car has heat, air conditioning, and power steering
Backup camera, reverse lights, and parking sensors all work like factory
Additional parts I am including with the price:
Spare set of complete gen 3 cylinder heads with valve covers
(3) brand new pails of One Ethanol e85r
Holley fuel drum pump
MAF crank pulley install tool
Coilover spanner wrenches
Spare motor oil, spare trans fluid
Factory royal crimson hood
MMR spark plug gapping tool
Spare Brisk race spark plugs brand new
Spare set of factory spark plugs
Spare procharger belts and pullies
Spare vacuum hard line (brand new in packaging)
Spare Fore fuel fittings
Spare fuses for fuel system
Spare set of factory axleshafts
Motion Raceworks engine diaper
VP Racing fuel can
Factory battery box and battery
Extra carbon fiber pieces for roll cage
Spare 3.5" aluminum tubing
Second co2 bottle for parachute setup, always good to have a second bottle around
Spare factory automatic diff pinion flange
Complete mod list:
Front Suspension
Viking J325AK-250K Crusader Front No Sway Bar Coilovers
J&M JM-24231 Caster Camber Plates for Viking Coilovers
Rear Suspension
BMR SP088 Drag Springs
BMR SM760 Rear Shock Mounts
BMR WAK761 Camber Lockouts
BMR TR005 Toe Rods
BMR TCA045 Spherical Vertical Links
BMR BK050 Billet Differential Mounts
BMR BK048 Delrin Cradle Bushings
Viking VIK-B358AM Crusader Double Adjustable Drag Shocks
UPR 2701-01 Billet Spring Spacers
UPR 2002-26 Delrin Billet Adj Rear Camber Arms
Steeda 555-4050 Hardcore Diff Support
Steeda 555-4117 Spherical Control Arm Bushings
Front Brakes
Baer 4261560 2.0 Drag Brakes
Rear Brakes
Baer 4262695 Deep Stage Brakes
Chassis
BMR BSF760 Front Bumper Bar
BMR KM761 K-Member
Ford Performance M-1700-M Tie Down Kit
Safety
Motion Raceworks 141300 Parachute Mount
Motion Raceworks 14030 Co2 Parachute Release Handle and Cable
Motion Raceworks PRK-CC Parachute Cable Holder
Stroud 430 Parachute
Jegs 60201 Co2 Regulator
Jegs 60207 2.5lb Co2 Bottle
S&W Racecars 95-8245 Co2 Bottle Roll Cage Clamp
Kirkey 55 Series 55170 Aluminum Race Seat (x2)
Kirkey 55 Series 5517011 Black Tweed Seat Cover (x2)
Racequip 741001 5-Point Racing Harness (x2)
UPR 2100-03 Crotch Strap Bracket
Competition Engineering C4906 Rear Seat Brace (x2)
FatHouse Fabrication S550_KSM Seat Mount (x2)
FatHouse Fabrication 8.50 Spec Roll Cage
Summit Racing SUM-590102 Roll Bar Padding
Allstar Performance AAF-ALL14100 Roll Bar Padding
Allstar Performance ALL10289 Window Net
Allstar Performance ALL10219 Window Net Spring Bar
Jegs 70020 Window Net Mount Kit
Quik-Latch QL-38 Hood Pins
DEI 010487 Heat Shroud for transmission lines
Interior
Motion Raceworks S550DS Steering Wheel Button Mount
Motion Raceworks S550PS Steering Wheel Button Mount
Motion Raceworks 151004 Momentary Button (x2)
Joleobee 1000003-501_B Magnetic nGauge Mount
GlowShift GS-AV3 Air Vent Gauge Pod
Five Star Race Bodies 096-820-Flat Rear View Mirror
Wildside Composites 920-WS9011-1 Carbon Fiber Roll Bar Protector
Summit Racing SUM-G1999-2 Helmet Hook
Ford Performance GT350 Rear Seat Delete
Ford GR3Z-7277-AA MT82 Shift Boot
Exterior
Optic Armor OA-MUS151-4DB Polycarbonate Windshield
Sto N Sho SNS135 Front License Plate Mount
Anderson Composites AC-HD18FDMU-SA-DS Heat Extractor Carbon Fiber Hood
Ignition/Electrical
Brisk RR12s Spark Plugs
N2MB Wot Box
Flaming River FR1003-2 Big Switch and Lever Kit
Moroso 74051 NHRA Sealed Composite Battery Box
ETX18L Power Sports Battery
XS Power 586 Tall Battery Post Adapters
Bussman HMEG AMG Fuse Holder and 250 Amp Fuse (Main Power)
Fastronix 500-040 AMG Fuse Holder and 250 Amp Fuse (Alternator Wire)
JQuad 3/8" Four Post Power Bussbar
EWCS 2/0 Gauge Welding Wire with 5/16" and 3/8" Lugs
Zemoner B08BQZVMKS Copper Battery Terminal, Positive
QuickCar 57-719 Remote Battery Charging Terminal Kit
Speedway B01N9VXH3D Battery Post Adapter Bracket
Moroso 74144 Battery Cable Thru Connecter, Red
Moroso 74145 Battery Cable Thru Connecter, Black
Fastronix B07NBKWT7Q 3/8" Stud Cable Covers
Duralast DL07047 3/8" Battery Post Adapters
Duralast GT215B Battery Terminal and Cable, 2/0 Gauge
Fuel
Fore Innovations 42-832 Triple Fuel Pump System
Injector Dynamics ID1700x Injectors
One Ethanol e85r
Engine
Procharger 1FW602-SCI F-1A-94 Stage 2 Tuner Kit
Procharger 2FWSU-003 Crank Support System, custom modified mandrel with 1/2" socket head
Gates K080670 Belt
Stainless Works M152H3OR 2" Off-Road Long Tube Headers
SLP 31067 Loudmouth II Muffler (x2)
Custom Dump Style Exhaust
TiAL Q 50mm BOV (x2)
Turbo Guard TG-MX-1 Ultra
Custom Rear Mounted Breather Oil Catch Can
ATI 918047 Super Damper
Kinetik CoyoteSaverStud Crank Saver Stud
UPR 3025-01 Billet Drain Plug
Plazmaman Billet Coyote Intake Manifold
Vibrant HD Quick Clamp Throttle Body Assembly
BL Fabrication WGG-CLM-TB-ADP Quick Clamp Adapter
Drivetrain
ATI 401603SC Fuel Comp Supercase TH400 Transmission with Transbrake
ATI 401935 Roller Tailhousing
ATI 202815 Coyote Bell
ATI 403610 Moroso Oil Pan
ATI 925170 Quick Disconnect Cooler Lines
ATI 408424 Outlaw Converter
ATI 915719 Flexplate
ATI 951378-8 Flexplate Hardware
ATI 915607A Crank Sleeve Adapter
ATI 406611 TH400 Transmission Catch Can
ATI 100001-12 Transmission Fluid
Ford AC3Z-7007-A 2015-2017 6r80 Engine Block Plate
Ford FR3Z-4851-B 2015-2017 MT82 Rear Pinion Flange
Ford 52027 2015-2017 MT82 Starter Motor
Ford DU2Z-14474-CA PCM Pin Terminals
DSS JPCSH-6-A 4" Aluminum TH400 S550 Driveshaft w/ Sonnax Yoke
DSS RA8555X6/RA8556X6 2000hp Axle Shafts
Energy Suspension 3.1108G Transmission Mount
JPC 14311 S550 Shifter Mount
JPC 14305 S550 TH400 Crossmember with Driveshaft Loop
Hurst 3162001 Quarter Stick Shifter
Hurst 2488601 Reverse Switch
Lokar X1211147 Locking Quick-Disconnect Firewall Mount Dipstick
Derale 13950 Atomic Cool Transmission Cooler Kit
Aeroquip 2252-4-4S 1/4" NPT Swivel Fittings
Moroso 93103 TH400 Transmission Pan Gasket
Tuning
HP Tuners 62001 nGauge
Lund LR-BBNGP Omega Boost Box
Lund ZT-FPS Fuel Pressure Sensor
AEM 30-4402 Transmission Temperature Gauge
PBD Gold Package
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Why am I selling the car?
My wife and I are planning to relocate to Alaska. This does mean the car needs to be sold.
Please let me know if you have any questions at all.
Decible
Georgia
Sam
2023 Mach 1 HP
This is a steal for a well built street/strip car 😳
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
I agree. Hoping it can find a nice new home so that me and my bride can as well :crackup:
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Pics from tonight
wingnutt
@FL410
michael
350R Procharged w/P1X
Oh wow…I have been stalking your threads since I found this site, and I cant believe you are letting her go…the car, clearly not the woman 😂
I grew up all over Minnesota but totally get the alaska thing…I always wanted to as well 😉
…good luck on the sale, and bump for a killer deal!
ThatStockStang
New york
Vinny
Lookinnnn
This is a fucking build! And the price is just AMAZING! Honestly would be on a plane tm to pick it up if it didn’t have the cage and chute. EVERY OTHER CAR ON THIS FORUM TAKE NOTES!!!! THIS CAR IS WORTH THE MONEY THE REST ARE NOT LMAO. GLWS 💪🏽
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Updated the listing
