Livernois Motorsports
- Oct 25, 2014
- Dearborn Heights, Michigan
- Website
- www.livernoismotorsports.com
- S550 HQ
- 2016 Mustang GT (TVS 2650) (6R80)
2015-2017 MUSTANG HOOD STRUT KIT
Want another touch to make your Mustang different? Why not remove your hood prop rod? How would you like to simply start to lift your hood and let the Hood Lift system take over. Your hood will lift and hold firmly at the raised position - no wind or bumping will knock your hood down on your head. These gas struts are rated at 90 LBS to hold up OEM and specialty hoods.
Due to the leverage when open, a 90 LBS rated strut will keep the hood open securely.
Fits 2015-2017 Mustangs - does not fit GT350
Ford Performance Hood Lift Kit w/ Laser Engraved Ford Performance Logo.
90 LBS Rating
Designed for all OEM base Mustang, Mustang GT and many aftermarket hoods.
These hood lifts utilize two gas struts that lift and hold the hood without the need for a prop-rod.
Made from lightweight steel and aluminum, they feature a durable black powdercoated finish to give your engine bay a much cleaner appearance.
Includes the necessary mounting brackets.
If your aftermarket hood is lighter than the factory hood, use caution when opening the hood due to the power of the strut.
