Lethal Performance Suspension Packages NOW AVAILABLE!
Chris@Lethal
Wellington Florida
Ford
Now available from Lethal Performance, in collaboration with BMR Suspension, are suspension packages designed to put the power down on your S550 Mustang! We have packages for every driver, Drag, Track/Handling, and Street for the Daily Driver! By removing the sloppy OEM Chassis and Suspension pieces in favor of stronger and more rigid components so that the car will perform at it’s best. These kits are made from only the highest quality parts to ensure peak performance and reliability.
Take a look at the kits available at the link provided
http://www.lethalperformance.com/catalogsearch/result/?q=LP-BMR-S550
If you have any questions feel free to give us a call at 561-753-8105
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Tested and true!
Thanks for working with us and putting this together for the consumer Lethal, this is a great set-up!
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Will you guys look to offer a slightly more 'budget' Street/Track package? The thought I had was FRPP Struts/Shocks + BMR Handling Springs + BMR Sway Bars + BMR Cradle Lockout. This would not only be nice on price (~$1350), but also pretty easy install for most.
This would be a big jump up in handling from stock and would be more budget conscious. Obviously we could just order all that ourselves, but packages are nice!
Matt@Lethal
Lethal Performance
We are definitely looking into adding more options, so we will keep this in mind.
valentinoamoro
US
15 TY Mustang GT
Just saw your BMR track/street package. OMG, this is exactly the suspension setup I was gonna piece together! (Was waiting for koni yellows but now am wondering if it's worth it, I haven't heard a single neg about the frpp dampers).
You guys should run this against the PP in slalom and autocross and report results...maybe even hand a car equipped with this set up to some auto bloggers to try out. I suspect it will be a lot better than even the well received frpp track pack. I also wonder if it will run with a GT350 around a road course with wider wheels and tires - no engine mods.
Grea job, I know what my next move after exhaust is.
nicktechla
Los Angeles, CA
www.nicktwaddell.com
Nick
2017 Camaro ZL1 Red Hot
I need this setup
