LED turn signals
DB83
Granny Shifter
Spain
2017 Mustang GT
Which are the best, most reliable, and OEM looking turn signal out there.
I would like them to operate as DRL's and then switch to turn signal when indicating. Not fussed with the sequential turn signal part.
Only issue is i need them to work on an EU mustang.
Any help would be greatly appreciated!
mike3105
UK
2018 (pre-FL) manual GT
If you want plug and play you're gonna only have one option for an EU mustang, the Coplus ones. They do exactly what you're asking for, and have an EU friendly plug. I did the wiring myself and got some from AliExpress for around ÂŁ60. The plug and play you'd be looking at ÂŁ150ish.
DB83
DB83
Granny Shifter
Spain
2017 Mustang GT
hmmmm....not a huge fan of light pattern or the way it switches. Ideally i want the diode dynamics ones.
Can the diode dynamic ones be wired to work with the eu mustangs?
mike3105
UK
Yup, will just need some wire taps/soldering
Smoothly
Hungary
2016 Shadow Black Mustang EcoBoost
Only one additional wire is needed per side. Works perfectly.
DB83
DB83
Granny Shifter
Spain
2017 Mustang GT
Haven't started talking this but do you have a picture of how/where to tapped in to? Does it work perfectly as a DRL, the switch straight to an indicator, then straight back?
mike3105
UK
I'm not sure what the wiring is like on the DD ones, but the EU has two plugs - one for DRL and one for indicator - each with two wires - black for ground and other for power. You need to take a tap from the indicator (striped wire from memory) and pop that into the wire that's not covered by the DRL. I think it might be a different connector, so you might be better cutting and tapping two wires, but I'm not certain on what the DD one looks like. The two plugs are right next to each other inside the front wheel arch and I think the indicator is the outer one.
DRU842
Sydney
Andrew
2017 Ecoboost Lightning Blue
DB83
DB83
Granny Shifter
Spain
2017 Mustang GT
Sorry, not looking for tail lights, just the indicators at the front.
I ended up getting the DD ones, but haven’t had time to fit them yet
