was covered under the 5/60 warranty.Dealer now has the parts to replace the leaking seal. This is where the axle shaft attaches into the differential. Leak rate of about 2 drops per day.. jeez...
No issues. The tech who did the job liked the blower. Curious: is there a TSB for this issue? If yes, do you happen to have a copy or know the number?Had the same issue. Mine was also the right side !!!!!!! BTW, the FORD repair bulletin also requires the wheel bearing to be replaced. This work
I believe engine torque might contribute to this issue. Next week I will be installing the STEEDA "red" diff bushings which may help with the axle seal issue. Time will tell.
I just noticed that you have a supercharger.....WOW! Lemmeno if the dealer gives you any grief about doing warranty work on a supercharged car???
