robmustang201528
15 mustang gt302blown
Has anybody used the launch control on the strip or the street? if so what are your thoughts? Did it improve your0-60 or quarter mile times?
He is talking about a slightly different type of launch control. The Mustangs system simply holds the revs on the manual transmission equipped car at your set level. It is up to the driver to release the clutch and get on the gas at the appropriate rate. You can do that as many times as you want, but you should be aware of how the clutch is handling the hard launches.One more question. is their a limit to how many times you can use the launch control feature? Can use it every pass down the drag strip or does it limit your use? Reason i ask is because i saw this video on youtube. He talks about how most launch control features on a car will only allow you to use it but so many times. youtube link below
Yes I would love to.try with track contol off but only at the track with street tires, its a big difference launching with these 373's gears.Another tip for the track is to try to be their when they open and get some of the first passes right after tbey prep the track, especially if ur on strreet tires.But again ur this wheel hop has to be fixed if anyone wants a good 60 foot time which is everything for the 1/4 mile.in my non PP, mt82 5.0, I was better off switching launch control off at the track this weekend.
even with advanced track completely off, launch control interfered with the launch once the system detected wheel hop. it would roll out nice for about 5 feet from the line, felt the hop and fall flat on its face for a split second then go again. consequently the 60' was terrible for me with launch control on. I also tried sportmode combined w/ launch control, out of curiosity. that was another catastrophe. the car did not like the high rpm shifts and pulled timing mid track on that one, felt like the car wanted to shut off for a few seconds during the run. didnt do that again....
there was another guy at the track in a mt82 w/PP car that had track mode turned on with the launch control and the system worked good for him. i dont have PP, so i didnt have a "track mode", just launch control. maybe that was the difference?
anyways, i was on street tire, and I was better off not using anything. i was launching at 1500 rpm, with everything turned off including launch control. Wheel hop is terrible on this car but its still a blast to drive! launch control on the street works decent though. i leave it at 3000rpm.
