But since you already have some experience with the damping set about at what Koni describes the beginning of step 2 to be, you could perhaps start by adding a quarter of a turn to the front only. I suggest this because people do tend to run firmer front damper settings up front in front engine RWD cars, at least while the OE front to rear spring balance is present. Go up in maybe eighth turn increments from there before tweaking for understeer-oversteer balance.Tech Note
KONI ADJUSTMENT TUNING GUIDE
Suggested Adjustment Procedures For Road Racing Use
Adjusting The COMPRESSION (Bump) Damping Control
(Very Important to do this FIRST!)
Bump damping controls the unsprung weight of the vehicle (wheels, axles, etc.). It controls the upward movement of the suspension as when hitting a bump in the track. It should not be used to control the downward movement of the vehicle when it encounters dips. Also, it should not be used to control roll or bottoming.
<snip>
Adjusting the REBOUND Damping Control
Once you have found what you feel to be the best bump setting on all four wheels, you are now ready to proceed with adjusting the rebound. The rebound damping controls the transitional roll (lean) as when entering a turn. It does *not* limit the total amount of roll; it *does* limit how *fast* this total roll angle is achieved. How much the vehicle actually leans is determined by other things such as spring rate, sway bars, roll center, ride heights, etc.
It should be noted that too much rebound on either end of the vehicle will cause an initial loss of lateral acceleration (cornering grip) a that end which will cause the vehicle to oversteer or understeer excessively when entering a turn. Too much rebound control in relation to spring rate will cause a condition known as "jacking down." This is a condition where, after hitting a bump and compressing the spring, the damper does not allow the spring to return to a neutral position before the next bump is encountered. This repeats with each subsequent bump until the car is actually lowered onto the bump stops. Contact with the bump stops causes a drastic increase in roll stiffness. If this condition occurs on the front, the car will understeer; if it occurs on the rear, the car will oversteer.
STEP 1: With rebound set on full soft and the bump control set from your earlier testing, drive the car one of two laps, paying particular attention to how the car rolls when entering a turn.
STEP 2: Increase rebound damping three sweeps (or 3/4 turn) on all four dampers and drive the car one or two laps. Repeat Step 2 until the car enters the turns smoothly (no drastic attitude changes) and without leaning excessively. An increase in the rebound stiffness beyond this point is unnecessary and may result in a loss of cornering power. Note: As with the bump settings, this point will probably be reached at one end of the car before the other.
However, individual drivers may find it desirable to have a car that assumes an oversteering or understeering attitude when entering a turn. This can be easily "dialed-in" using slightly excessive rebound settings at either end.
Reverse both the adjustment and the pressures and you're good. More in front, on both.Sounds good. Thank's for the tips Bmac & Norm. I'll give 1.25 front and 1.5 rear a try. I was also told I should lower the front tire pressure by 3psi or so over the rear? So like 33psi front and 36psi rear. Does that sound about right?
That's true.So i thought Koni yellows only had one adjustment and i was told by Koni it was rebound only, that was on my 2013.
Agree, good write up!!!That's true.
But you can use their tuning procedure for double-adjustables (both bump and rebound) for single-adjustables. Just skip over the bump thing portion.
Norm
