J&M Products New Mustang Coil Over Conversion Adapter Kit
Hotpart.com
San Luis Obispo, CA
2002, 2006, 2015 Mustangs
2005-2018 Mustang 2.5 Coil Over Conversion Kit Made in the USA​
J&M Products/hotpart.com has designed and manufactured a new 2.5″ Coil Over Conversion Kit. When installing Coil Over struts on your 2005-2017 Mustang with Caster Camber Plates this all new Part # 24240 kit should be seriously considered. The upper spring perch supplied in many aftermarket Coil Over kits will not properly mate to the profile of the bottom of many aftermarket caster camber plates and or the 2.5″ spring.
Features and Benefits:
  • Ball bearing spring seat assembly
  • Billet aluminum machined adapter
  • Suspension loading is through the roller bearing body of the adapter and not the spherical bearing which is not designed to take the axial loads
  • Fits all caster camber plates that use the stock style spring seat (All 2005-Present J&M Plates and most others 2011-2017, excluding GT500)
  • Works with stock upper strut mounts
