Interior LED Kit
magnetticmadness
Southern California
2018 mustang gt premium OW 10spd
Ok so has anyone found a way to successfully put the micro 2 add a fuse into fuse #36? i have had 3 different micro 2 add a fuses and none of them even fit into that slot. Any suggestions? thanks!
magnetticmadness
Southern California
ok edit to above... i finally got a working micro 2 add a fuse into the darn fuse box, but im really a beginner when it comes to electronics. the add a fuse has two fuse slots in it and i have no clue how it works. also im not sure if i even have the proper amperage. the led kit im using is just one led strip so i assume its not much amperage. any help would be greatly appreciated. and if someone has a setup of it with pictures that would be even better! thanks!
magnetticmadness
Southern California
[MENTION=21771]jvivlemore[/MENTION] what fuse slot did you use? ive been looking for a fuse slot that would have it turn on when the door opens or unlocks. Do they stay on after shutting the door when you get in the car?
