How do these spark plugs look
ven377
San Diego
2015 GT
My car is procharged and i have been getting codes p2006 and p2007 and ive had a flashing check engine light. A member told me a flashing light was missfiring so im installing some ngk 6509 gapped at 0.32.
I get the check engine light on around 3 gear at 5psi about 5-6krpm and i feel the car loose power and the check engine light pops on.
ven377
ven377
San Diego
2015 GT
I just finished the install of the ngk 6509 and I got the same problem. At about 5-6k rpm I felt the loss of power and check engine light came on once again with p2006 and p2007. Any ideas?
ven377
ven377
San Diego
2015 GT
Can a bad CAI filter cause this? I Have not cleaned mine in about 8 months.
sigintel
Ray
2018 GT
What did you use to get codes?
Where did you look those codes up?
If you google those codes what do you get?
What member told you a flashing check engine light was missfiring?
There are a couple red flags here that might hinder you getting help.
Plugs have nothing to do with IMRC.
Whose tune are you using?
How long have you been running the SC?
ven377
ven377
San Diego
2015 GT
I used the diablo tuner to get the codes.
Looked them up on google. Imrc bank1 bank2 stuck closed.
Using peocharger tune.
Been using it for about 8 months.
I do 1st and 2nd gear pulls and the power is there till 7krpm then i hit 3rd and as soon as i hit about 5-6k rpm feels like i loose boost and check engine light turns on.
whatsup62
Jupiter
I had the same codes quite some time ago. Found out during my header install the electrical connector on one of the IMRCs was broken. Sounds like same issue or possible vacuum hose off on the IMRCs.
