Horn sounds when locking car
Gdyup50
Denison, Tx.
Ron
2016 GT Premium
Hi guys, I'm sure this has been answered somewhere but I couldn't find it. My horn sounds when I lock the car, but the horn itself doesn't work when I try to use it. I'm assuming the relay and fuse are fine since I hear it when I lock the car, so what would be the problem? Thanks
Johnny Rockit
Massachusetts
Johnny
2022 Mustang GT 6-speed. 2015 F-250XLT,73 Torino
What about when driving down the road? Is it just when parked that it fails to work?
IPOGT
Alan
The button on the steering wheel would be the first thing I’d check based on your experience.
ORRadtech
Atlanta, Georgia
I've never had the airbag/ horn button off. Is the underlying switch discreet or part of something?
My first thought was the clockspring.
IPOGT
Alan
Honestly, I’ve never taken mine off. Just a simple guess.
Gdyup50
Gdyup50
Denison, Tx.
Ron
2016 GT Premium
Gdyup50
Gdyup50
Denison, Tx.
Ron
2016 GT Premium
What button?
ORRadtech
Atlanta, Georgia
All the time
If it works when you lock the car but not from the steering wheel I'm going to stick with my guess of the clock spring. Do all of the other steering wheel controls/buttons work like they should?
IPOGT
Alan
There is a horse on your steering wheel. If you press the horse, the horn is supposed to operate……there’s a switch underneath the cover.
IPOGT
Alan
No idea. Obviously though, if the action of pressure on the pony triggers the horn, then there must be some sort of mechanical switch or contact.
Gdyup50
Gdyup50
Denison, Tx.
Ron
2016 GT Premium
Yes
IPOGT
Alan
I was thinking simple circuit stuff, trace and move on. Apparently clock spring is a “thing”
Anyone have a good primer on the subject? Wondering why they call it a clock spring..
ORRadtech
Atlanta, Georgia
Yes, but it doesn't appear to be a discreet switch. It appears to be built into the airbag. Watch the first minute or so of this video. The black connector is most likely the horn wiring to the clock spring. The yellow connectors are the airbag connectors. So unless that black connector is loose or disconnected it's either the clock spring or the airbag. Or I guess it could be a fuse somewhere or maybe the BCM but, I know the clock spring can be an issue with these cars. It would be easy enough to check, pop the airbag off, pull the black plug and jumper across the wires. If the horn works, it's the airbag. If not, more testing is needed.
IPOGT
Alan
:like: Thanks Dave. Just what I wanted to see.
