Hmmm BC Coilovers?!
S550 Sema
North Jersey
2018 GT PP2
Nice s550 sema!! What're your wheel specs and what size tires are you going with? I had those wheels on my last car.
I also plan on taking out the rear perches. Keep us posted!
19x9.5 et15 19x10.5 et30 an I'm probably gonna end up going with 235/35 an 255/35.
IG - S550_Sema
byklin
CA
2015 Magnetic GT
Wow that's some aggressive offsets. You're gonna have to run some decent camber up front
POOPonYOU
I Do Stupid Well
Paramount, Ca
2015 Race Red GT Premium
What's the minimum drop that you can get from the coilovers? Can you get them to near stock ride height?
hawkbox
Arizona...in the heat
'18 GT Premium PP
Kit can go above stock height from what I could see - Did did about a 2" drop on mine.
hawkbox
'18 GT Premium PP
Here is the kit laid out on the bench, will upload install pics later.
byklin
CA
2015 Magnetic GT
Are you guys touching the rear shock at all to adjust height? Or are you guys just adjusting the spring mount?
hawkbox
'18 GT Premium PP
I had that same question - I went back and reviewed the destruction manual as I was installing and it says to adjust the shock length to meet both shock perches so adjust them to meet the perches and set the ring!
Make sure you tighten the ring sufficiently - I recommend before final mounting because that ring is a son of a bi$%%$ to get to once they are in!
byklin
CA
2015 Magnetic GT
Yeah I think I'm gonna leave both rear perches in but maxed out and see how that goes and if I want lower maybe I'll adjust the shock
byklin
CA
2015 Magnetic GT
Also what're those green things for? The ones next to the front assembly in the photo?
Supa LA
Drop a gear and disappear
So. Indiana
2015 Guard Metallic Mustang GT PP
phrenetiK
IF YOU QUOTE PICS I H8 U
houston
2015 GT Premium PP Recaros Race Red
were dyno sheets ever provided by BC?
i thought you were joking too then remembered that there are shock dynos and maybe that is what you are talking about
Supa LA
So. Indiana
