High speed braking issues.
15gtRob
Tampa FL
Boosted 2015 Mustang GT
I have a 15 GT with the Performance pack. I've noticed when braking from high speed the car tends to want to track to the left. Im not sure where I could even fully test this safely. I've had a few races in Mexico that make me pretty nervous because the car is seriously pulling to the left. I have a Novi 2200 on the car, dss drive shaft and axles, and American muscle rear wheels 20" with Nitto Nt05r 315 35 20. Any ideas?
HrDrift
Torrance
2015 mustang gt
might want to start checking your tire pressure first. Brakes could be a problem but assuming its a new car it shouldnt. Faulty Suspension can be a problem too.
15gtRob
15gtRob
Tampa FL
All the suspension is stock still and I'm running 36 psi each up front. I've checked it with a tire gauge and the readout on the dash.
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
I would check for a hot brake to rule in (or out) a possible caliper issue.
HrDrift
Torrance
2015 mustang gt
Check your rotors, brake caliper and pads.
Niz55
Us
17 GT350
36 cold? If you are running 36 cold that's around 40 hot. Drop it down to 32 psi cold.
