Help with subwoofer install
atlas10Spd
california
2022 mustang gt, 2022 chevy silverado
I’m adding an aftermarket subwoofer/amp setup to my 2022 Mustang GT Premium with the factory B&O system. I’m also planning on using a EPICENTER Micro PRO for the signal.
I’m trying to avoid cutting into the factory wiring if possible. My plan is to use a plug-in harness at the factory B&O amp and run the speaker-level signal to the EPICENTER Micro PRO.
Ideally, I want to tap a full-range signal before any factory low-pass/bass filtering so the EPICENTER can properly restore missing bass frequencies.
Has anyone with the B&O system done something similar? If so what harness did you use. Thank you! Pic for attention
