Help with GT350 Wheels
Grintch
Hunstville
2015 GT PP
Thanks, lowering it is something I was going to hopefully do in the near future.
I am debating between the FRPP Street or Track Pack.
Probably will go with Street since I don't intend to go to the track.
How could lowering it make it flush though?
Wouldn't they still poke out?
Lowering generally "adds" more negative camber, which brings in the top of the wheel. Or you can just add camber directly. Visually if the top of the wheel/tire is under the fender the tire is under the fender, even if the bottom of the tire sticks out another inch.
Spacers in the rear will probably help with a more balanced look.
Smaller tires will help with poke a little, but are somewhat counter productive.
Ashiq73
Ashiq73
Southern California
2016 Mustang GT 6 Speed Magnetic Metallic
the ford handling packs dont lower you nearly as much as a drop spring like sportlines, which would tuck your wheels nicely. i know that doesnt go with your "plan" but id hate to see you do the whole pack and not get the results you want. id suggest making an exception in this case. plus, you can fix the issue now for like $250 instead of saving and waiting for a $1300 kit, that you could piece together from used crap in the classifieds.
Thanks for the advice GuardGT.
But I don't want a big drop.
The Ford Suspension will only drop the car about an 1" which is fine by me.
Even if it does not tuck the fronts in that much, I am ok with that.
The first day I got the wheels I was freaking out but the more I look at it now, the more I like it.
So I think with a 1" drop, it will be fine.
I also do not want excessive camber (as that can cause more wear on the tires), although it may not matter for me since I only drive my car on the weekends a little bit.
So in the end I think I will still end up getting the FRPP Street or Track.
Thanks
tyshenry
DFW
'15 GT w/ PP
The wheels will look perfect once you lower and add camber just like everyone has said above.
PICANTE
SoCal
15 ecoboost pp
Where in SoCal are you? I'm lowered on roush coilovers, which I believe are an inch drop, you can mount your front wheels on mine and see if you like the fitment once it's lowered
Niz55
Us
17 GT350
Thanks
good choice on the handling pack. I would also suggest getting MM camber caster plates to dial in your camber if you want more negative.
Ashiq73
Ashiq73
Southern California
Ok, I have to ask, what do you all mean by "Tramline"
Digital_Synapse
Mass Effect Field Expert
San Antonio, TX
2015 Triple Yellow Mustang GT PP
Tramlining is the tendency of a vehicle's wheels to follow the contours in the surface upon which it runs. The term comes from the tendency of a car's wheels to follow the normally recessed rails of street trams, without driver input in the same way that the train does. The same effect is sometimes called Nibbling.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
I have 295 front tires, I can verify that this comment is false. My car tramlines like a MoFo, as do all 295+ on our cars.
Mine rocks 305/325 Ive had it tramline before a few times.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
shelbywannabe
Orlando FL
Robert
2016 Black Mustang GT PP
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Lower it by 1-1.5 inch the wheels will sit flush perfectly.
If the wheels sit flush at OEM height, it will be too tuck in when lowered.
The rears don't tuck in as much when lowered same height is because the different suspension geometry.
Plus if you want the GT350 look, you gotta lower it by 1-1.5 inch.
shelbywannabe
Orlando FL
Robert
Steeda Progressives give you that drop. Thats what I went with and it looks great :thumbsup:
Ashiq73
Ashiq73
Southern California
Yea can't wait to get my track handling package.
That will drop it by an inch.
Hopefully real soon
