khushdeep
I have 2016 gt/cs, i changed the digital cluster, sccm and heated steering wheel that a got from a 2021 Gt premium. I didn’t know about the HSWM and the other wiring. If i want it to make it work, i have to get the HSWM and the wiring. But what is the role of FCIM, i dont understand?Well this has been a long process but finally accomplished it. Quite of bit of trial and error through this process. I don't expect a lot of people to do this mod due to cost but still wanted the info out if you end up going for it. This all started with upgrading my 2016 to the 18 digital dash and following suit with adding the heated wheel. The dash upgrade is way worth more than going after the heated wheel but ultimately I wanted to see if it could be done. I didn't figure this out on my own and it was a colaboritve effort and I'd like to thank those for their efforts, solutions and experience. @DanMc85 for his Fusion built wiring harness and ultimately figuring out the final piece necessary (18+ FCIM), @p6cl for finding the 18 FCIM after he found one as well and @breeves002 for his brain storming efforts. If i've forgotten anyone I apologize but thanks nonetheless.
Here's the parts list in a nutshell and this applies to the 15-17 years:
Premium (Sync2 or Sync 3) is required.
18+ heated steering wheel - it comes with the new function buttons. If you are going to upgrade to the 18 dash as well, order the appropriate one that has the right buttons for full functionality. If NOT upgrading the dash, order the cheapest heated Mustang wheel you can find and transfer your 15-17 buttons over to it.
Heated Steering Wheel Module (HSWM).
Wiring and connectors to connect everything together. DanMc85's harness that was made for his Fusion is a complete carbon copy of what is needed for our Mustangs. I'll include a link for the parts than need to be ordered. Here is a link to his build which is highly helpful.
http://www.2gfusions.net/showthread.php?tid=6598
18+ Air bag.....yes it really is needed as the 18+ wheels are different. My 16 on left and 18 on right.
18+ Clockspring with Steering Wheel Control Module (SCCM) and heated wheel capable.
And the last part and will still be somewhat difficult.......the Front Controls Interface Module (FCIM) from a premium 18 and up. This FCIM doesn't have to come from a car with a heated wheel as both I and p6cl bought just an 18 one without 401a which includes the heated wheel so any premium 18 FCIM and up should work without issue. They look identical to the 15-17 but they are not and I was not able to upgrade the firmware on mine to make it work. Ford does not have a price of this and they are outsourced and cannot be ordered like a regular part. I have made multiple attempts at getting this and ultimately the cheapest and only way I know of at the moment is to source it from a salvage yard that is parting out a car. This is why this mod became difficult. I'm sure as time goes on, they will be easier and easier to source. You can see by my newer one that it has the 18 start button. I have a red GT350 start button but the newer metal one is actually very nice and I'm going to run that for now. Here is also the part number for the one I received.
Lastly is coding using forscan which is no big issue and I'll list that below in regards to just the heated wheel.
To enable the heated wheel in the FCIM, an 8 must be added to 7A7-01-02 in XXX8-XXXX-XXXX
To code in the HSWM, it only has two lines to put in. I believe the first line is its timeout and the second controls the temp. Different parameters can be programmed but I don't know them and this is what the new Mustangs are programmed to:
714-01-01 and should be 0000-0000-1D
714-02-01 and should be 0250-5050-10
In regards to the SCCM, no programming is necessary if you are NOT upgrading the dash but your 15-17 buttons will have to be transferred over. If upgrading to the 18 and up dash, coding is required and you should refer to that post.
To have the icon on the home screen and climate screen, the APIM will need:
7D0-01-01 XXXX-XXXX-XOXX (O= 4 is heated wheel only, 7 is heated wheel and heated seats, and 6 is heated wheel, heated seats, and cooled seats). I have a 6 programmed and you can see it on my screen shot and it is touch capable of activation, intensity level and deactivation.
The little red light in the wheel icon means it's on. It gets warm very quickly and I don't know how long it stays on yet.
The climate screen looks funny in this pic and what you see isn't how it looks in person. Looks totally normal in person or like the pic two above.
Sooooo, what's the cost? I need to go over my parts since it's been so long from when I started this venture but off the top of my head, possibly around $800. Quite a bit for just warm hands but I was pot committed and wasn't going to stop. I'll try and get better pricing when I get a moment as well as part numbers but those tend to change from time to time.
EDIT:
Here are the part numbers for this mod plus what I paid and can be associated with the dash mod as well.
2018 airbag - JR3Z-63043B13-CA - $295.35
Housing Assembly (SCCM) - JR3Z-3F791-HA (There are different versions but this one is for heated wheel/inter windshield wipers) - 81.69
Heated Steering Wheel - JR3Z-3600-GA (Again, different types available but this is a heated wheel for digital dash and without adaptive cruise as it comes with the button controls) - $257.84
You can see the part number for the FCIM that I got from above and I payed $220 from a wrecking yard.
The parts list and numbers for the wiring harness that has to be made are listed in the link that I supplied above from DanMc85 and that comes out to around $200
So now lets go with a price tag of $1055 with some shipping charges to apply as well. Again, probably not a worthwhile mod but some will do it and I was in for the win when I started it.
END EDIT
Those that have 18's and up and have a premium without the heated wheel can add it for cheaper than us older model folks. They don't need the airbag or the FCIM and that helps a lot but will need all the other parts. I haven't looked at one that closely but it's possible the wiring harness may already be in place and just the HSWM will need to be added but I have no idea at this time.
EDIT:
I’ve since sold my stock FCIM and 16 airbag which has recovered $450 in this project. END EDIT
Good luck if you try it and it will work. I'll edit this post for more info, corrections or other crap I think of if it helps.
