Half shafts or drive shaft first?
5cent
westlake la
kyle
2016 mustang gt shadow black
Just upgraded shifter now I'm looking at half shafts and drive shafts. Not sure which one I should do first.
wildcatgoal
@sirboom_photography
TBD
If you don't have forced air, then get a driveshaft. Don't need either, though.
5cent
5cent
westlake la
kyle
I will be doing boost for sure but want to build the car first. And I don't want to break a a shaft at the track. Lol the drive shaft is more for power transfer and lighter rotating mass. I know it can handle the power. So I'm guessing the shafts would be the best first. Lol
jhatley7
2016 White GT PP, 2022 F350
If you track the car with good rubber, I would do the halfs first.
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2025 Mustang DH HP
Ya. I have the PP and I think instead of blowing a ton of money on slicks I am just going to upgrade the halfs, a lot cheaper running radials. I think if you plan on launching the car with good tires axles should definitely be the first one to upgrade as they are more likely to fail. A lot less likely on the autos than the M6 though.
jhatley7
I run Hoosier 28x10 slicks and they aren't that expensive. Are you going to run your dr's on a second set of wheels?
Slicks are easier on the m6 drivetrain.
wireeater
Virginia
wheelwell.com
Rich
I don't want to run rears without fronts because I hear it's pretty sketchy with slicks. I think I'd like to be able to run drag radials that I can just toss on and drive to the track.
I priced a set awhile back and for front runners and rears bias-ply was $2,500 or so.
My plan is to find a set of used half shafts and rear set of DR. Seems like it would be much cheaper. I don't go to the drag enough to justify spending a ton of money but would like something for when I do.
RoadCone
Ohio
2016 Competition Orange PP
What setup do you have? Another $650 or so I imagine. I was debating the Mickey Thompson Drag radials and set of 17's. I heard radials are better than slicks on these cars because of the weight.
Right now my car is in the shop having DSS 1400 hp axles, DSS D.S., Steeda Braces, bushings and more to get ready for the track. I want to see if I can hit an 11 second run.
Sorry about posting this in someone else's thread.
jhatley7
That's a awesome idea! I just remember in my research that Dr's are harder on the m6 than the a6.
jhatley7
Are you a6 or m6?
I have dss 1400 half, dss 4" aluminum, cb005, rst twin disk and TR6060.
Drag set up is welds front and rear with the Hoosier 28x10 and mt skinners up front.
Street is vs07 wheels 305 nto5 front and 345 nto5r rears.
RoadCone
Ohio
Are you a6 or m6?
M6 Performance Pack....
Braski
Lancaster, PA
Traded 2015 Blk GT Prem PP on 2019 Corvette GS 2LT M7
I went with slicks just to protect the whole drivetrain. When I did the math slicks, mnh front runners and race stars where cheaper than axles, drag radials and 2 rims.
jhatley7
jhatley7
And lighter!
