Guess my new dyno results
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
How much boost?
The shop didn't have a boost gauge, so I still have to go on what my boost gauge says. Around 12 psi at @7,300.
I am on a 5.00" pulley so I shouldn't be making that much boost.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
Pretty conservative timing for E70. Being safe at that power level and on the stock engine I get it.
Looking at this log you got knock very early in the pull. Knock on E85 especially on just conservative timing is usually caused by one thing. That is inconsistent lambda. at the start of the pull its very inconsistent which probably caused the knock. After that the knock sensors were happy, but the fuel was still pretty inconsistent. You see long drawn out fluctuations in lambda and short term fuel trims. My guess is the transport delay was increased too much. I would not be happy with this tune.
That is good to know, I can't read logs as well as I would like so I thought everything was good. That's what the tuner has been telling me at least. I have datalogged quite a few times doing wot pulls on e70, I think this is the only pull I have that shows positive knock.
Still though, I want my tune to be near perfect.
Can anyone else confirm that my log should look cleaner? Thanks
whatsup62
Jupiter
1 hp different than me. Same set-up pretty much..Im at 10psi
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
Well heres your File you posted on datazap. It makes it easier to see the data.
http://www.datazap.me/u/markmurfe/log-1500454597?log=0&data=10-11-13-14-15-18&solo=4-10-11-14-15-18
I have your measures lambda and short term fuel trims selected. You can see at idle your mesured lambda is a wave with length of about 6 seconds. It should be going up and down a lot faster and not get so far away from lambda 1.
In the zoomed out view, during the pull, fuel looks good, but go to this link with it zoomed in on the pull and you see how much the measured lambda is moving around. .72 to .79 to .77 to .79 to .74 to .77 to .75..... bank two is a bit better but still moves around.
http://www.datazap.me/u/markmurfe/l...8&solo=4-10-11-14-15-18&zoom=2188-2612&mark=5
you may need to click on the lines to rescale.
Tommy V
Brookly park Md
Tommy
Code:
ip
http://www.datazme/u/markmurfe/log-1500454597?log=0&data=10-11-13-14-15-18&solo=4-10-11-14-15-18
I think .72 to .79 is a bit of a difference,but the rest are pretty normal.I have not seen many wheir measured a/f were identical on both banks.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
How does this log look? I took this last night after having lund add in an extra degree of timing.
The car feels really good and pulls hard.
Sorry I don't know how to use the data zip thing.
markmurfie
Hawaii
Mark
Code:
ip
Im not talking about bank vs bank. This is the fluctuations in measured AFR on one bank. bank vs bank they are very close.
10.7* .72= an AFR of 7.7
10.7* .79= an AFR of 8.45
Thats moving around alot for ethanol. Because it needs to be so rich it makes it more sensative to fluctuations when it comes to knock.
markmurfie
Hawaii
Mark
That pull it didn't knock, but measured afr was still moving around a bit not as much as the first log. Your timing is conservative for E85 which give it a bit of saftey.
http://www.datazap.me/u/markmurfe/l...13-18&solo=4-10-11-14-15-16-18&zoom=1748-2115
I took a snip and marked it so you can see how much its moving. bank to bank they follow each other ok.
markmurfie
Hawaii
Mark
just want to be clear, this could be an exhaust leak as you did a exhaust modification. Your tuner may not be able to fix it. They should have pointed it out.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
Well... I don't like the sound of that..
How do I check for exhaust leak?
Tommy V
Brookly park Md
Tommy
Gotchs i couldnt see the log,yes thats a big difference for one bank,i had an issue similar to this wheir my car was not getting into fuel inrichment fast enough,bought it up to jon and he made some changes,i was not getting any knock though.
markmurfie
Hawaii
Mark
Usually a spot of black soot can be seen. Check where headers meet heads and around O2 sensors.
