GT350 Rotors & Pads
Demon Coyote
Naperville, IL
2015 Mustang GT
Well looks like the GT350 rotors and pads are now available at LMR:
Rotors:
https://lmr.com/products/2015-Mustang-Brake-Rotors
Pads:
https://lmr.com/item/LRS-2001R/2016-shelby-gt350-front-brake-pads
I'm sorry if anyone already post this up. If they have then I will delete the post, just thought I would share though.
Also available here at Levit Town Ford:
LH Front Rotor:
https://levittownfordsupercenter.com/oemparts/FR3Z-1125-F
RH Front Rotor:
https://levittownfordsupercenter.com/oemparts/FR3Z-1125-E
Rear Rotors:
https://levittownfordsupercenter.com/oemparts/FR3Z-2C026-C
Front Pads:
https://levittownfordsupercenter.com/oemparts/FR3Z-2001-J
Rear Pads:
https://levittownfordsupercenter.com/oemparts/FR3Z-2200-E
dubster99
Nor*Cal
2015 Ingot Silver GT PP
On the pads on LMR, is that per side? I believe that's the case. $192 for a front set from Levittown...yikes! Are the rear rotors drilled like the fronts or solid?
Demon Coyote
Demon Coyote
Naperville, IL
2015 Mustang GT
I believe the pads come as a pair for the front and a pair for the back. At least everytime I've purchased them that has been the case lol. Yes the rears are drilled as well.
dubster99
Nor*Cal
It just calls them a "set" on LMR, and from the pics it looks like it's only 2 pads for $109. Ford dealer has a "kit" for $192. Leads me to believe that it's $192 for both fronts, and on LMR it's $109 per side. I wonder how these stack up against aftermarket pads.
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
So how to make those rotors fit a GT PP?
Anthony@HTM
SF
GT350 Track Pack
I think you'd need new calipers as well but I'm not 100%.
You're right.
You'll need the caliper, disc and steering knuckle at the very least.
It would be more cost effective to buy the AP or Girodisc two piece discs.
dubster99
Nor*Cal
LMR also has the caliper for $299 ea...not sure about the spindle/knuckle.
Budwise
Austin, TX
2015 GT PP
Unless going carbon ceramic I don't see any benefit over the GT PP brakes. For once, the brakes are not a weak point for a Mustang.
Anthony@HTM
SF
GT350 Track Pack
I agree, pads and fluids are really all you need for the average track day with this setup.
