MrXXX0
- May 1, 2021
- Braselton, Ga
- Evan
- 2021 Mustang Mach 1
Was finally able to order a GT350/R center gauge pod , install it and replace the stock one that had oil pressure and vacuum. Now it has a higher oil pressure read out (meh) but more importantly it has oil temp now. If anyone would like to tell me what the vacuum gauge was for besides just being a gauge that moves with on and off throttle inputs I'm all ears. I'm pretty sure the only reason they have that vac gauge is because of just how much it moves with inputs and most people like seeing gauges move.
With the install it was pretty straight forward. Pull carefully on the dash trim from passenger side, it's gonna sound like it's snapping and breaking but it's not. When you get to the center be careful because the harness plugged into the pod isn't all that long and could easily be ripped out. After that switch over the pods with a T20 bit. Plug the pod in then press the trim back in working it from steering wheel side to passenger side and then you're done. Check and make sure lights come on and pressure and temp gauges function. One down side for some would be the lose of my color on the center gauges but I already had mine set to Grey so it's not noticed by me. Just a heads up for that if you're interested.
Part number is pictured in 3rd pic
