DANA44
- Dec 27, 2015
- Central Connecticut
- Dave
- 2016 v6 convertible
In my garage on jack stands
I replaced the Ford OEM DMF (32.6lbs) with the Ford BR3Z-6375-D 5.0 flywheel 21.2lbs.
FMK1026 EXEDY OEM Clutch Kit for the 5.0 . The .750 Slave Cylinder Spacer from Calimer's Transmissions marketed for this conversion.
Ford Performance 5.0L Coyote Flywheel Bolt Kit
M-6379-C
Ford Racing Pressure Plate Bolt and Dowel Kit
M-6397-B46
Both flywheels share the same dimension and location from the crank mounting with the flywheel ring gear. Establishing starter compatibility and a similar distance from engine block mounting surface to the pressure plate fingers with both engines.
While I do not have the dimension from the 5.0 mt82 trans mounting surface to the face of the concentric salve cylinder bearing face fully extended by the boot spring I took a leap of faith based on Calimer selling .750 the spacer.
With engine and trans mounted I have 25.4 mm of compression on the concentric salve cylinder boot spring from the fully extended position. Based on pictures my 3.7 mt82 with the spacer set up the concentric salve cylinder bearing face lands on the same spindle location as the 5.0 mt82.
With the drive shaft still off and spinning the trans output I got rudimentary sense of peddle travel that seemed normal.
Performed a crank relearn
First drive all normal better shifting smoother at 80+mph. Seat in the same position centered around clutch peddle
Still under 500 mile break in
M-6379-C
M-6397-B46
