Sounds like you're hitting a guardrail in the ECU. Two things to check - first, is there a setting you haven't adjusted, and second, will the ECU handle a V8 at more than 6500 RPM. You might be running out of headroom.We are doing some tuning and for some reason the motor goes to dead pedal limp mode when we go over 6500 rpm? the map does not show anything wrong? air/fuel, oil temp and pressure, trans, etc all good temps and pressure.. water temp at 190 -
