UnhandledException
I am installing ctek battery tender and will install the permanent connector to the fusebox’s positive terminal with the eyelet connector. The 10mm nut there is damn hard to get off and I want to make sure while tightening it, I tighten it properly. Does anyone know the torque spec?
Also the same question for the ground connection to the strut tower.
Thank you
Thank you
