pmor4243
Hoping to get some thoughts here. During some roll racing a while back, I noticed I was getting a pretty big drop in fuel pressure when going WOT. It would only be for a moment, and then would jump back up to 60-70psi for the duration of the pull. I grabbed a log to a couple of days ago essentially matching the same conditions to see how things were doing, and noticed that my fuel pressure dropped down 19.9psi then jumped back up once again.
Quick details on the car. 19 GT, Procharger P1x @ 9psi, LP52 injectors, Stock Fuel Pump, Meth injection
Datazap log link: https://datazap.me/u/pmor4243/fuel-pressure-dip?log=0&data=9-26-31
Im not sure what to make of this. I understand that fuel pressure will drop in this scenario regardless, but dropping down to 19psi seems problematic. I tried a BAP to see if that helped and it made almost zero difference. I also want to point out that this "roll race" type condition is literally the only scenario where this happens - high rpm, stab the throttle, immediate jump to near max boost, etc. In all other scenarios this is not a problem.
I understand that the easy answer I may get here is "add a fuel system" and I do agree that would probably be a good idea, and who knows, maybe that IS the answer. That said, the car makes 695hp at the tire, and I am not intending on going any further, at least for a while which makes a fuel system less appealing to me.
So I'm curious if there are other potential options to help alleviate that initial drop in pressure.
