Front Sidemarker Bulb Help!! Diode Dynamics LED bulb (not switchback bulb)
Jsy622
ATL
15 Mustang Ecoboost Performance & Premium
I ordered the front switchback bulbs from diode dynamics and having trouble getting the driver's side led bulb out. I've tried twisting counterclockwise but it won't budge :frusty: I gave up after my knuckles got bloody. Has anyone had this issue? Any resolutions?
DRKHORS
Mark
'18 F150, '23 Mustang GT
I installed mine a couple of weeks ago and didn't have any issues. I will say that the connectors were very snug from factory. Just a 1/4 turn counter clockwise and then simply ease the plug straight back. There are teeth on the plugs that you must line up with the housing to remove the plug/light.
One other tip: once you get those factory bulbs out and are placing the DD LED's in make sure you press them FIRMLY into place. The new LED's are a very tight fit and if you don't get them seated properly you may end up with a bulb falling down in the housing which from what others have said is a PITA to get back out. I haven't had any issues with mine at all...
101charley
Franklin TN
Charley
2015 GT Magnetic, 400A, 6AT, 3.55, MBRP Street
Yes. Same problem. These little buggers are a PITA to get out. Bloody knuckles and lots of grunts before it budges. The right rear side marker will NOT budge. Fords must have glued it in.
fstenuf
Iowa
2018 Mustang GT PP2
I didn't have trouble getting them out...I had trouble turning them back in to hear the "click". maybe i need to hit the weights??? lol
Jsy622
ATL
The weird thing is I somehow put the old diode dynamics bulbs in a while back. I am replacing with new ones because they are flickering. I guess I'll try using a wrench or something.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Weird. Try pushing in then turning counterclockwise.
ronv95
Munford, TN
Ron
2015 Mustang Ecoboost
Had this same flickering, I switched to some Sylvania's off Amazon and they are way better. I purchased numerous stuff from DD and had to RMA about everything...awesome customer service but products have been disappointing.
