Front left lights issue
javierhe
San Jose, CA
Javier
2015 Mustang GT, 2020 Raptor, 2022 Mach-e GTPE
Hi all,
I had the front left side of my 15'GT repaired after a crash, and I noticed that when I turn on the left blinker, the lower left light turns off, then comes back on when you turn off the blinker.
I'm guessing this might be a wiring issue... does anybody have seen something like this, and if so, can you share some insight about how to fix it?
Thanks in advance.
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
Lower left light? Are you talking about the fog light? If so, see if the right side behaves the same way, it's normal for the fog light on one side to be turned off when the turn signal on that side is activated. This is done to make the turn signal light more visible...
javierhe
javierhe
San Jose, CA
Javier
Thanks for the feedback, I still need to check it (apparently only happens on the "auto" mode and I haven't found the time to do a proper test yet) but I'd swear that was not happening before.
