Fore Triple pump - self install
rainmaker
NW Indiana
2015 Mustang GT PP
Has anyone self installed a Fore double or triple pump return fuel system? Does it come with detailed instructions? Do you use the stock line for feed or return? What pumps for E85? Is the wiring plug & play or require splice / hack? Does your garage wreak like fuel from the new lines when the car is not in use? What vendor did you buy from? Any tips, vids, pics, etc? thanks!
beefcake
Bethel
2018 Ford Mustang
there are many ways you can route the system. its kind of personal preference as far as things like filter / regulator placement etc..
wiring is much easier with an fc2 or fc3. fc3 is if you want to stage pumps, meaning run one all the time, and have the 2nd or 2nd/3rd kick on under boost.
but, you can use just wires and relays on your own if you choose.
teflon lines will give no odor, sometimes the starlite can give a little, but the starlite are slightly easier to work with.
we are pretty much the goto for fore systems if your looking / need help building one, you'll want the 267 (walbro 465s) for e85
beefcake
Bethel
2018 Ford Mustang
