SH!FT
My install of the Fitcamx Dash Cam (Front 4K+ Rear 1080P+ 128G):
It's a great system! I have one in my Tacoma as well.
Powered by rain sensor circuit.
FitDVR app works well with iphone.
Storage: micro SD card
Front camera install instructions are good: install video
OEM
Front cam installed.
Rear cam installed.
Phone app view at dusk.
- Power and Snapshot buttons
- Blue and red LED indicators
- Microphone
What I see from the driver's seat.
Fitcamx vs. OEM
The Install:
I tested the system before installing in the car. (This is not necessary.)
The Fitcamx provided wiring harness connector has labeled wires #1, #2, #3. I plugged in the rear camera, then put 12 volts to wire terminal #1 and ground to #3. I downloaded app to my phone and was able to test all of the camera functions.
Front camera install:
Super easy. Just followed the install video. I did add a zip tie and sticky mount to the power cable to keep the connector away from the flimsy dimmer sensor. Tried for nearly an hour to get the rear camera connector to fit in the cover as well. No luck without risk of damaging the rain sensor. The rear connector was instead taped and tucked into the headliner. Everything is easily hidden. All cable slack was pulled to the rear windshield.
Rear camera install:
the instructions are a bit vague. Here's a Generic Fitcamx front/rear camera install video but... I found quicker way to run the rear cam wiring through the headliner.
Here's what the underside of the headliner looks like. It's a fiberglass shell with a decent gap between the roof.
I was able to sit in the passenger's seat and feed a snake straight backwards between the sun visor mount points. Next pull the cable from the rear to front windshield.
The rear camera needs to be mounted centered to avoid having a rear passenger hit their head on it. I was able to use the defroster pattern to help me do that accurately. The distance between the circled elements below is 13 7/8". The mounting surface of the camera bracket is 1 1/2". I marked my ruler at 6 3/16" then marked the rear windshield from inside with a dry erase marker.
The camera mount was flipped so all of the bracket would be hidden under the black window paint. I locked the camera in the highest position by tighten the 2 screws. Dry fitting the camera to the alignment shown below results an indent from the cable on the headliner when the camera was removed. I created a small notch in the headliner at the indent using a Dremel. Slowing opening the notch until the camera dry fit comfortably and the OEM gap between the headliner and rear windshield was restored. The connector was taped and cable was fished back into the headliner
OEM
Rear cam installed.
- Microphone
Fitcamx vs. OEM
The Install:
