doulos4jc
......looking^
The inside latch is on the left kick-panel - kind of toward the driver's door from the dead pedal. The underhood latch is "down" as you slide your hand in, and pushes to the right to the unlatch.
In the trunk under the spare tire unless you ordered the PP in which case it is only available if you sit in your seat at a 90 degree angle and chant "Sum Alla Bum" over and over.
hood latch is under the hood.
NVulture, must have info when you get around to popping the hood. ;)Look at the front bottom of the driver door... go slightly right and close to the floor, the latch is right there
