Experiencing some DTC’s and need some help!!
23jldavis
Dd234dd#
Jacob
2019 mustang gt
So for starters I recently took my car in to be serviced (the only code that showed up when I dropped it off was p0025 and a couple misfire codes) when I got the car back the codes now are p0302,p0301,p0305,p303,p0369, and p0365 i checked my spark plugs and coils and they were good, replaced the bank 1 sensor 1 camshaft position sensor, cleared codes and the codes still came back.
below are the images of the invoice I received. The vct solenoid replacement makes me think i need a crank relearn procedure but i want to hear everyone else’s thoughts before i jump the gun and spend $400 on a sct device and have it not work. Car drives much better but has a solid CEL and sometimes the car will have a rough idle and small ticking sound coming from the right side of the engine along with a flashing CEL but it’ll go away after 10 or so seconds—————- I’ll also like to add my throttle doesn’t seem responsive like when i put my foot on the throttle it just doesn’t seem responsive, idk if it’s the 10r80 being at the highest gear so RPM’s stay low but id like to point that Out as well. Well that’s about all I have to say with the situation, I’d hate to take it back up to the dealership (3rd party not a ford) for service as they had my car for 2 months and I want to know if it’s something I can do by myself, thanks in advance everyone
Nobuemon
Monrovia
Nikita
2020 Ford Mustang GT Premium
you paid $6500 and got the car back in much worse state than before the drop off? send it back to them and TELL them to fix that shit. Could've gotten an engine rebuild for that kind of money.
23jldavis
Dd234dd#
Jacob
2019 mustang gt
No, it has a warranty so I paid $150
Nobuemon
Monrovia
Nikita
$150 for "labor"?
For a potentially easy fix you could check if everything's connected properly and no wiring is damaged.
23jldavis
Dd234dd#
Jacob
2019 mustang gt
When I replaced the sensor, it was plugged it good and the wires showed no damage like corrosion, obviously that’s that’s face level and I didn’t dig deep enough to fully see if there’s any damage
PSI
US
16 Mustang GT, 17 F150, 14 Audi Q5
Holy shit they really fired the parts cannon huh? All that exhaust work for what?
I’m leaning towards either a wiring issue due to rodent damage/corrosion possibly not near the VCT solenoids or something is up with a cam phaser. Check the ECU connection too.
23jldavis
Dd234dd#
Jacob
2019 mustang gt
Might be a dumb question to ask but to check the wiring near the solenoids do I need to take the valve covers off? And how do I check the cam phaser? Same thing I mentioned before?
Skye
≈39N
"Skye" Mach1 N2144
What is the brand name of the warranty? Its conditions? Any options for selecting another service location?
Paddles
TX
Richie
2023 Mustang GT
If you're seeing a flashing CEL I would stop driving it until that's resolved
