Exhaust Flutter at start up
5.Oh Crush
DMV
Ra
Mustang
Has anyone had this? The exhaust sounds bad until I turn on active exhaust or turn car off and restart. Is the flap sticking? Thanks.
Sammy
Walnut Creek, CA
2017 GT350
The same thing happened to mine. Fire it up and in a span of 2 seconds it goes from very loud-----more muted-------very loud. Kind of strange. It is like the system is testing the flaps on startup. Then it settles down. I only noticed it on cold starts.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Normal caracteristic of the exhaust valves, they all do it.
Bender
SE PA
17 LB GT350R HR909, 22 AB GT500 CFTP
If the car is turned off with the mufflers in sport mode, it just the computer re calibrating the valve servos since it designed to be in normal mode upon start up. If you place the car back into normal exhaust mode it should go away or only flutter once
Ronp
South Metro Atlanta, GA
Ron
'22 GT500, Iconic, '19 F150 ScrewFX4
When you first get in the car, press in the clutch for a couple seconds before starting and it wont do that. You'll actually here the exhaust valves opening and closing. I cant stand when i forget and it does what you are talkjng about.
5.Oh Crush
DMV
Ra
Mustang
Thanks. I had the problem over the weekend again even after warm start. I will hold clutch longer next time.
:cheers:
crazymayhem
Daniel
2017 GT350 LB
Wasnt there a trick like that - or is that it - to start in sport exahust mode?
nastang87xx
San Diego, CA
2016 GT350 Track Pack
So THAT's what that humming noise is...guess that shows you how often I drive in normal mode. :D
5.Oh Crush
DMV
Ra
Mustang
I thought it always started in sport mode on initial "growl" and defaulted off. Then you have to turn it onto sport mode. Of course, I can put it in reverse and it does not do the initial sport mode growl.
nastang87xx
San Diego, CA
I always thought the car did a valve check on startup depending on a certain number of conditions. I never could figure out what they are but the clutch thing does make sense.
J_Maher_AMG
Newfoundland, Canada
Justin
2017 GT350R (HR057)
The humming noise you here when you first put in the clutch is actually the fuel pump priming, you'll hear an audible almost clicking noise of the exhaust valves opening/closing.
I agree though, normal mode may as well be called non-existent for me :D
crazymayhem
Daniel
2017 GT350 LB
Im pretty sure I read it somewhere in a post in a thread last year, but cant find it via the search function, but didnt somebody post a trick where holding down the clutch for a few seconds before actually starting cycles to valves open mode? Or did I misread that somewhere?
nastang87xx
San Diego, CA
Okay, that makes more sense. I thought it was something with the injectors/pump initially before so was definitely thrown off. The click'ish noise I really had to listen for.
