ESS 10rib water pump pulley, ars smaller if needed.
andrewtac
TX
mark
F250. 2020 GT 400A
I am not sure on the belt routing on an ess. I am Running a vortech, 10rib setup. ARS did not have any water pump pulleys in stock when I needed one, so got an ess. The belt was rubbing between the 20% ati and the ess water pump pulley when I would get on it. The clearance between the two was about a sheet of paper. I got the ARS, the pulley is 4.2" and the ess was 5. No more rub. Just another option if you need something different.
